BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: dyno jet quick shift NEW TOPIC NEW POLL POST REPLY
zx
posted November 20, 2008 06:13 PM
any one use the quick shift in conjunction with there commander if so lets here some feed back i want to loose the weight of the air shifter and its componets
put up or shut up
sleeperbusa
posted November 20, 2008 07:22 PM
Mine works like a charm!
2008 Hayabusa.
64", stock clutch, stock gears, foot shifting,1441cc, 8.98 at 157mph at 260 pounds. Holdin it down for the big fellas..
2013 ZX14R.....to be continued.
  Ignore this member    Click here to visit SLEEPERBUSA's homepage.
Halvefast
posted November 20, 2008 07:41 PM
I incorporated mine it my airshifter, works flawlessly.
Before adding the airshifter components I just used the kill feature off the horn button
and used my foot to pre-load shifter, worked just like an airshifter,
but you had to have your foot on the peg.
ECTA Ohio Mile 195.132mph
almost_les
posted November 21, 2008 12:34 PM
+1 i use the same set up. so much easier since there is no kill-delay to adjust, and you can still clutchless full throttle shift with your foot on the street, or it you run out of air.
zx
posted November 22, 2008 01:48 PM
thanks 4 the replies i just need to try the set up there seems to be no real feed back stated that the system is junk or not ill be the ginny pig in my area here in pa. i run at reading m.c. we have our own club track open to public check us out at www.readingmc.com click on razcing news if any body isin the area check us out this spring good ol racing
put up or shut up
0.20836997032166 seconds processing time
