BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: pistons hitting plugs? NEW TOPIC NEW POLL POST REPLY
posted October 01, 2008 05:40 PM
got the bike together tonight, fired it up, and my noise was worse. damn! so i pulled the plugs, i think #2 might have been getting hit by the piston
ill get some pics uploaded
tcchin
posted October 01, 2008 06:15 PM
Time for some R0045Q-10's or some RU01-31's!
posted October 01, 2008 06:26 PM
Tim, please speak english for the beginner lol. I have no idea what you are referring to. possibly McM Carr stuff???
osti33
posted October 01, 2008 06:34 PM
They are spark plugs. Pricey little guys too. 69 dollars a piece for the NGK's and 44 a piece for the Denso's!!
http://www.sparkplugs.com/results_cross.asp?pid=R0045Q-10&x=69&y=15
http://www.sparkplugs.com/results_cross.asp?pid=RU01-31&x=51&y=15
posted October 01, 2008 06:48 PM
thx Ryan. wow, ive never seen a flat plug like that before...couldnt i just put an extra washer on my plug to gain clearance? (like the kind used for indexing)
would I have damaged anything by this? rod bearings? little dents in the piston would be fine right? if its my problem that is... im still not sure
im hoping its a gasket. i stacked 2 used ones instead of using new ones because i didnt have any new on hand. ive reused them before like that without problems, but i had sealed them with high temp silicone(copper stuff). but ive since been told to never use that as it will kill my wideband O2 sensor......
pics for the experts:
#2 is the worst one, with tiny marks on #1 also
JACKSHOW
posted October 01, 2008 10:21 PM
What was your piston to head clearence? Got pictures of your pistons before they went in?
posted October 02, 2008 12:58 AM
i think it was around 36 thou?, ill have to double check. regular JE 1287 pistons with a bit of sanding on the sharp corners
posted October 02, 2008 03:11 AM
it looks like you moght be just slighly tagging them.
Could just take .010-.020" off the area on the piston under the plugs? or get shorter plugs.
i know nothing about indexing
NGK CR9EKPA: overall length = 2.800; - protrude into cc = .200"
Denso IU01-34: overall length = 2.685, - protrude into cc = .105"
SteddyTeddy
posted October 02, 2008 04:48 AM
What kind of compression ratio are you setting up to be hitting the plugs????
posted October 02, 2008 07:17 AM
The head was milled 5 thou and I don't have the base gasket in. But with the chamber mods its 12.47 : 1 cr
SteddyTeddy
posted October 02, 2008 07:28 AM
Man that doesn't sound tight enough to hit the plugs, but I've never dealt with the ZX12 motor. My ZRX has loads of room for the plugs even set tight at 13:1 and the ZX14 I was into last week looked to be the same.
posted October 02, 2008 09:48 AM
I thought I would have lots of room too but I didn't clay anything. What's it kinda looks the same where it was "hitting" as where it sparks I won't know unless I look @ a piston I guess
Stuart Racing
N.H.R.A . Dragracing.
posted October 02, 2008 10:30 AM
Thats what I was thinking too....5 thous. isn`t really that much.....But as long as nothing else is going on , 1,or 2 washers outta cure the problem,JMO....
P....
posted October 02, 2008 12:51 PM
its really about 15 thou lower than stock with the base gasket/ block shim removed though.
so no reason to tear down the motor?? ill pull the washers from some old plugs and ill be ok??
Karl, indexing a plug is usually done on a car, but i think its getting phased out for newer better spark plugs(like what we have in bikes). you use a washer (play around with a bunch of different thicknesses)to make the open end of the plug gap (think old car style with the big "J" shaped electrode) face the intake valve.
Stuart Racing
posted October 02, 2008 02:35 PM
Ya, I still do it on my KZ motors...But does take some screwing around to get it just right....Brand new plugs its easy because the washer hasn`t been squished yet....
Newer bikes , the plugs are almost straight up an down in the head.....
P.....
posted October 03, 2008 05:38 PM
well my motor is still making a noise. i put 2 washers on the plugs so i would have lots of clearance, and i used the high temp copper silicone on my exhaust gaskets, which cured for roughly 22 hrs. its not plugs or gaskets, so im thinking valves or bearings. fukk. no more races this season for me. gotta do a bunch of stuff around the house and dads shop, then its tear down time to see what the damage is. if its the crank, ill make a 1350 stroker, if its the head, hopefully it will be an easy fix and ill put some money into electronics and suspension over the winter...Ill have pics when i rip it apart
JACKSHOW
posted October 03, 2008 05:52 PM
Drain oil and check for material, if no material its probably the valves. Put a base gasket in it and check the valves to see if everything is good and you are good to go.
posted October 03, 2008 06:02 PM
im thinking it may be out of time? i had some huge bangs going on. could that have screwed up my adjustable cam sprockets?
ill check oil either way
JACKSHOW
posted October 03, 2008 08:31 PM
If the cams are in wrong you need to reinstall your valvetrain to make sure you dont drop a valve. Happened to me!
Stuart Racing
posted October 04, 2008 10:35 AM
It`s probably the bearing on the cyl. that was hitting the plug.....HOPEFULLY NOT.....
posted October 04, 2008 02:02 PM
+10
ninja12
posted October 05, 2008 10:12 PM        Edited By: ninja12 on 6 Oct 2008 06:14
or it could have spit a shim.
Is it missing?
Do a leak-down
posted October 07, 2008 01:12 AM
leak down or compression test?
posted October 07, 2008 03:15 AM
leak down!
compression test gives a hint at CR and general health, but leak down will tell the story, exh valves? int valves? rings? both? how bad?
we did a leakdown on TRNorBRN's motor immediately upon returning from Maxton.
95% - 6% - 95% - 95% = bad ju-ju, exh valves on 1,3,4 toast.
NINJA12
posted October 07, 2008 08:03 AM
Yeah, like karl said , Leak down will tell you soooooo much more.
When you find a leaky cyclinder, listen to the exhaust, intake and oil fill plug.
problem could be exhaust valves, intake valves, or piston/rings.
If you don't hear anything then listen to the cyc next to it for a bad head gasket.
Snap-on makes nice stuff, but harbor freight has one that will get the jog done very reasonable.
After all it don't really matter if you are leaking 5% or 6%, you're not going to do anything about it. IF its over 10-15% you must fix.
0.25437808036804 seconds processing time
