BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Glowing shift light NEW TOPIC NEW POLL POST REPLY
stuart racing
N.H.R.A . Dragracing.
posted September 10, 2008 02:35 PM
Glowing shift light
Just installed a Dyna shift light....When I rev up the motor,the light is glowing,or coming on real dim...But when revved to 6000 base setup it comes on nice and bright,still just a little dim just before.....Just cruising around it will be dim all the time above 2 or 3000 rpm`s....Anyone have this happen before...Green hooked into light blue tach wire, black grounded to tank hold down bolt by fuse box.....Any clues???
P....
posted September 10, 2008 02:47 PM
shouldnt it be 8000 base rpm?
NOX
PMRA / TMRC Super Street 4022
posted September 10, 2008 02:51 PM
My NLR shift light activation every once in a while will flicker at 8000, never really understood why........, it works fine........
I hate electronics............lol
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
stuart racing
posted September 10, 2008 03:26 PM
Scott . you are right....8k is base.....I spliced the red switched hot wire into the wire that runs back to the airshifter solinoid from the fuse box on top of the tank...Muzzy setup kit....I wonder if I shoulsd just dedicate the switched hot to just the shift light....
AAHHH come to think of it,I think that wire that I spliced into is the engine kill wire for the air shifter,dammit...I need to go back out and take off the tank cover and check it out....
WOW.....
P...
stuart racing
posted September 10, 2008 03:36 PM
Nope, just checked it out...Test light stays on when I push the shift button.....
posted September 10, 2008 04:23 PM        Edited By: CrotchRocket on 10 Sep 2008 17:25
Shift lights...Dont need no stink'n shift lights
NOX
posted September 10, 2008 04:31 PM
You do if your rev limit is 12,200. Also, kinda hard to watch the tach with the front end two feet off the ground, better to have your eye on the track.............
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
stuart racing
posted September 10, 2008 04:57 PM
I haven`t had one since I`ve owned this bike,but I figued Iwould check it out and see if it would make me a little more consistant....
Good one NOX,Aint that the truth huh.....
aliveagain
posted September 10, 2008 05:20 PM
I could give you my clutch set up so it wouldn't go two feet off the ground. Sorry,I couldn't help myself!
SteddyTeddy
posted September 11, 2008 08:55 AM
Something is either hooked up wrong or you have a bad box. The Dyna should not be glowing until it is triggered to light up.
stuart racing
posted September 11, 2008 09:35 AM
Thanks Ted....I tried switching the two wires fronm the light to see if It made any diff...Stll works when revved up to rpm`s set for,but just glows in between the set rpm`s...I`ll call Dyna up see waassuuppp....
Thanks....
aliveagain
posted September 11, 2008 09:37 AM
sounds like it is starting to short
SteddyTeddy
posted September 11, 2008 09:40 AM
Yeah probably a transistor or chip going bad in the controll box.
stuart racing
posted September 11, 2008 04:11 PM
Well I just cam back from a test ride.....Went through the whole range 6k-- to 10k--- Everthing is working fine....I can really even notice the glowing while riding.....Maybe I`m seeing things,dammit man.....
Thanks alot,
Paul....
0.22247719764709 seconds processing time
