BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Got Spray? NEW TOPIC NEW POLL POST REPLY
sleeperbusa
posted September 05, 2008 07:19 AM
Got Spray?
I do!!!
2008 Hayabusa.
64", stock clutch, stock gears, foot shifting,1441cc, 8.98 at 157mph at 260 pounds. Holdin it down for the big fellas..
2013 ZX14R.....to be continued.
  Ignore this member    Click here to visit SLEEPERBUSA's homepage.
Nox
PMRA / TMRC Super Street 4022
posted September 05, 2008 02:07 PM
Nice
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
aliveagain
posted September 05, 2008 05:45 PM
Right in the face gotta make ya smile.What size pill is that?
sleeperbusa
posted September 05, 2008 05:48 PM
Yeah, my boy suddenly got the munchies. We had to stop and go eat..........
It's a .22 jet in each cylinder. Dry shot.
2008 Hayabusa.
TRNorBRN6001
posted September 05, 2008 06:28 PM
Holy Smokes Chris that spray burnt your hair right off!!!!!!
TFA 200MPH CLUB MEMBER!
posted September 05, 2008 06:32 PM
68hp. nice
how are you adding fuel? PC map? fuel pressure?
TRNorBRN6001
posted September 05, 2008 06:40 PM
Ya beat me to it KZ, just zipped over to schnitz site to check the chart!!! That sucker's going to hit like a frieght train!!!!!! That should get you to 200mph! Can't wait to see you running strong at the Mile!!!!!!!!
posted September 05, 2008 06:50 PM
yeah, <3 tech corner lol
sleeperbusa
posted September 05, 2008 07:31 PM
I have a Walbro 342 pump, modified regulator, a -6 fuel line, billet fuel rail and S2000 injectors, with a PCusb and a hub switch so that I can switch to a nitrous map on the fly. I am way in the negative numbers on the map now, leaving plenty of fuel to gain in the PC. I just hope that the fuel system will support it.
I will be happy with anything over 250, but I am shooting for 275hp.
2008 Hayabusa.
Gixx1300R
posted September 06, 2008 06:47 AM
Be careful with that setup. It has been known to freeze injectors
sleeperbusa
posted September 06, 2008 07:29 AM
That would SUCK, huh?
I have an LC-1 that I will be able to watch while going down track, to monitor my A/F.
2008 Hayabusa.
Gixx1300R
posted September 06, 2008 07:33 AM
I know 2 Busa owners that had their injectors lock while spraying doing top end runs with that setup. It doesnt seem to happen during drag racing. I guess the long duration and the cold temp of the Nitrous is what does it.
sleeperbusa
posted September 06, 2008 09:57 AM
That's good to know.
Do you know if they locked up trying to feed the shot, or frooze up because the shot was too close to the injector?
Were they using stock injectors or aftermarket?
Any info is appreciated!
2008 Hayabusa.
Gixx1300R
posted September 06, 2008 10:07 AM
They were spraying pretty big with stock injectors. I dont know the particulars but the injectors worked fine once they defrosted. I'm not saying that this will happen to you but if it does be ready to hit the kill switch.
sleeperbusa
posted September 06, 2008 10:47 AM
I sure will pay attention.
Thanks!!
2008 Hayabusa.
posted September 06, 2008 11:27 AM
did they stick open or closed, or part way? or all of the above? lol
Gixx1300R
posted September 06, 2008 02:36 PM
all the above,some stuck closed and some stuck open. Remember that Nitrous has a boiling point of -127F. The plunger and springs inside can freeze momentarily . Injectors arent designed to work in such cold temps.
TRNorBRN6001
posted September 06, 2008 06:12 PM
275HP on a street bike, now that'll be impressive!!!!! Too cool Mr. SleeperBusa. Hope to see it at the dyno sometime soon!!
tricktom1
posted September 08, 2008 06:58 AM
You need to enter the Texas Mile Shootout Nitrous class, unless you're scared, LOL
TEXAS MILE 261.5 MPH
gilberjj
Friend of Fast
posted September 15, 2008 01:41 PM
wow...... traction problems maybe?
sleeperbusa
posted October 12, 2008 06:53 PM        Edited By: sleeperbusa on 13 Oct 2008 02:56
Well,
after the Hurricane and shit going wrong,
i'm getting used to being behind the 8 ball.
I FINALLY have some results.
The Texas Mile is in 2 weeks and times a gettin short.
I have something wired wrong. When I touch the button, I have a quick 1/4 of a second blip.
After the blip, IT'S ON......................
Disreguard the blip, I'll get it found and fixed. Meanwhile, the current topic is the HORSEPOWER........
BILLETMAN would be SO proud of me. I took the big jets out and stepped it down 2 sizes.
At this point it's tuned for the mile.
With an A/F ratio anywhere from 11.9-11.4, from 8,500rpms, all the way to 11,500rpms, it should be comfortable enough to live thru a few gears.
At only 52lbs of fuel pressure and 88% duty cycle on the injectors, I feel like there it alot of safety built in here. This run is on VP C-16 with 4degrees of timing taken out.
This bike is easily capable of over 300hp with more tuning, but I'm trying to get that certificate in Goliad before I start pushing it.
I have WAY too much on my plate to hurt another bike.
I'll lean on it next year.
Right now all I have is 200mph in my sights.
Wish me luck folks.
Goliad, here comes SLEEPERBUSA!
2008 Hayabusa.
posted October 12, 2008 11:16 PM
great hp!
pretty weird glitch, but it shouldn't bother you at the Mile.
you have a progresive? looks like something is going S at 7300+/-
TRNorBRN6001
posted October 13, 2008 06:57 AM
Very, very nice!!!!!! Thats some power for a little old Busa street bike!!!!!
Close to 150HP on just motor at 7K not too shabby either!!!!
Dang, I can only imagine what those other jets would have run!!!!
Can't wait to see you running 200+++mph at the Mile Mr. SleeperBusa!!!!!
brickman
posted October 13, 2008 07:55 AM
that looks about like the shot i have on my zx10. with every thing closed up and the bike off. you can hit the button and if you have your head buy the ram air it well blow your hat off...lol
0.38918495178223 seconds processing time
