BIKEGOD
I'm lost???
posted August 27, 2008 05:48 AM
NITROUS. degrees???
SO...................
I'm running right now a "40shot" wet. on a basically stock zx14 motor. On a mix of super and c16. Currently the timing is set "stock"
If I put a bigger shot. "60"
I wont have time before this weekends event to buy any electronics to retard the timing.
Mike at NX said that as long as I run straight race fuel "c16" I should be fine. with stock timing.
What do you guys/gals think????
I'm a friend of your mom's,
Get in the car !
06redzx14
posted August 27, 2008 10:16 AM
if you want to be safe stay with the 40
posted August 27, 2008 01:39 PM
The Guy at NX is very Sharp, the problem with the 14 is its pistons are Softer than the 12 and for THAT Reason I would stay with the 40 shot!
people know I have a History of not liking the 14 but this comes straight from Pierre (Bear Racing that has about 4 of them from NOS to Turbo and he said they are Soft on top!
johnnycheese
posted August 27, 2008 01:56 PM
50 at the mile is no problem but you better have a good tuner
BIKEGOD
I'm lost???
posted August 28, 2008 03:31 AM
I have put the "60" jets in.
We will see how it holds up.
I'll let you guys know on Monday.
Get in the car !
posted August 28, 2008 07:26 AM
Did you put in 1 range COLDER Plugs?
shane661
posted August 28, 2008 07:34 AM
quote: people know I have a History of not liking the 14
I am busy "de-refining" mine...to the point that you may even like it!
BIKEGOD
I'm lost???
posted August 28, 2008 07:59 AM
quote: Did you put in 1 range COLDER Plugs?
Yes, I put the cr10ek's in.
Weather permitting I will take it to the track tmrw night..
Get in the car !
TRNorBRN6001
posted August 28, 2008 08:26 AM
That sucker's going to hit strong!! Enjoy!!!!
TFA 200MPH CLUB MEMBER!
trikchop
posted August 28, 2008 06:34 PM
quote: The Guy at NX is very Sharp, the problem with the 14 is its pistons are Softer than the 12 and for THAT Reason I would stay with the 40 shot!
the ring lans are really close to the top of the piston
posted August 29, 2008 08:13 AM
Does not give much thickness for a mistake!
