BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: zx14 wont shift to 6th NEW TOPIC NEW POLL POST REPLY
1969ca
posted August 20, 2008 10:12 AM
Ive been to the track and have never needed to go into 6th started to use spray and it wont go into 6th shifts fine 1st through 5th
MadnessRacing
Vmax and Busa Beater
posted August 20, 2008 10:28 AM
take it back to the dealer!!
Shorty's Performance
Team Madness Racing
shane661
posted August 20, 2008 11:07 AM
How are you shifting? Air?
ninja12
posted August 20, 2008 12:13 PM
Need more kill time.
posted August 20, 2008 01:07 PM        Edited By: CrotchRocket on 20 Aug 2008 14:07
This is the biggest complaint from the ZX14 owners using nitrous and 6th gear...
So whats Kawasaki going to do about it ???
NOX
PMRA / TMRC Super Street 4022
posted August 20, 2008 02:29 PM
Send it to RnD........., then it will shift...........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
NOX
posted August 20, 2008 03:03 PM
Oh, and mike, weather is starting to look better for Sat. to work on your clutch.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
1969ca
posted August 20, 2008 06:59 PM
yes its air with a shnitz kill box
zx12mark
posted August 20, 2008 09:36 PM
will it go into gear at say 6 or 7 grand when you push the button. if it dose try more kill time for high rpm shifts.it might be all it needs.but if that is the only gear it won`t go into at redline r&d will fix that.
1969ca
posted August 21, 2008 11:23 AM
My kill box is set to 60 should i go more kil time ??????????
zx12mark
posted August 21, 2008 08:56 PM
can you comment on my questions above............and yes more kill time.just for shits.
1969ca
posted August 22, 2008 09:10 AM
havent done shifts at 6 grand under load yet hetrack i go to you oly get about 4 passes on a friday night how much more kill time would u go
lietoome
posted August 22, 2008 11:15 AM
Do you have enough piston length to throw it completely into 6th?
Bottle pressure is good? Got gauges?
Does it shift into 6th under normal operation?
Race only bike? How many miles? Has it ever been in 6th gear?
1969ca
posted August 22, 2008 12:15 PM
1st q's dont know dose it need more from 5th 2 6th
2nd q's yes and 120 on the gauge
race race some street 540 miles 06 14 yes it has
lietoome
posted August 22, 2008 09:37 PM
My opinion.
First try the extra kill, your pressure is fine.
Adjust the piston so it will have a little more throw up top. With the airshifter the piston/rod will be all the way to the end of the throw for shifting into 6th.
I would also try to get some 5th to 6th gear repetitions under normal conditions.
IMO 540 miles is pretty low for the tranny to be broken in, especially the gears you use the least.
NOX
posted August 23, 2008 10:37 AM
I run 180psi.....lol,
On a big ram........
Seriously, I would run at least 150 psi., you are probably at 100 psi or less at the last shift
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted August 23, 2008 01:13 PM
try 150 psi like NOX said, and 65ms of kill time
Halvefast
posted August 23, 2008 04:09 PM
I used 75ms of kill, spraying only 45hp @ the TX mile last Oct worked for me.
Hope it helps {:~)
ECTA Ohio Mile 195.132mph
ninja12
posted August 25, 2008 07:36 AM        Edited By: ninja12 on 25 Aug 2008 08:37
Try 150psi first then add kill as needed.
Since you are spraying, I'd do both then back in down if needed.
Missed shifts and spray will waste oil on the track. know what i mean?
lietoome
posted August 30, 2008 11:51 AM
Did you get it working?
ninjafreek
posted September 01, 2008 06:59 PM
Probabaly driving through the clutch, Do you have any shims or heavy springs?
I've had a couple bikes do this in only high gear. Even with a 1,500 R&D tranny.
Nox
posted September 01, 2008 07:21 PM
If it drove through the clutch, it would shift...........
He is not driving through the clutch, trust me, I have been helping him with his clutch set ups........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
gilberjj
Friend of Fast
posted September 15, 2008 01:46 PM
haha....... your left foot could do the trick
ninjafreek
posted September 17, 2008 11:27 AM
Oh well mine didn't, Once I added static pressure it shifted in high gear fine.
My 2cents
0.27846908569336 seconds processing time
