BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: exhaust check valve NEW TOPIC NEW POLL POST REPLY
posted June 28, 2008 04:00 PM
exhaust check valve
i want to evac the crank case to the header like you see on drag cars, but i can only find 3/4 inch stuff. where would i find something appropriately sized for mine and dads 12s?
thx!
johnnycheese
posted June 29, 2008 06:14 AM
just be carefull the vacuum is not enough to do much help at high rpm
but enough at idle to starve the oil pump
posted June 29, 2008 08:44 AM
it should be just like running the crank case vent mod as far as vacuum goes right Johnny?
i did that last yr with no oil light flicker
NOX
PMRA / TMRC Super Street 4022
posted July 02, 2008 05:23 AM
Just do the CC VM
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted July 02, 2008 01:31 PM
im not going to use that this year because its bad for exhaust port flow, and messes with AFR readings... but i still want the vacuum
0.2228569984436 seconds processing time
