NOX
PMRA / TMRC Super Street 4022
posted March 07, 2008 07:20 PM
Compression question......
Okay, I have the full factory manual.........., and I know what the warm engine compression psi should be.........
But I have a cold motor, on a stand, and want to check the compression........., I know the reading will be higher, but what am i looking for , stock internal motor........
Just want to make sure all is good inside before I split the cases and swap trannies...........
Thanks.........., I would assume somewhere around 250psi or more per hole........., like 230 is for a warm motor.........,
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
Two Wheel Werkz
posted March 07, 2008 09:26 PM
the main thing would be as long as all cylinders check the same or close to
posted March 08, 2008 12:01 AM
Edited By: entropy on 8 Mar 2008 04:23
Nox,
i would be real surprised to see 250psi on a stock motor. I see that at about 14.5:1.
Something nearer to 200-210?
like 2WW says, look for consistent readings, and remember to open the throttle all the way as you are cranking the motor.
as we tapped, a leakdown will give much more useful info
NOX
posted March 08, 2008 05:50 AM
Leakdown test shows good...........
Just wanting to check all my bases........, other than being dirty on the outside, this motor looks to be in great shape, will check valves after breakfast with my daughter.......
No need to open the throttles........., motor is on a KnL stand......
Thanks guys.......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
NOX
posted March 08, 2008 10:01 AM
Valves all within spec, one exhaust is .0002 to .00004 out of spec......., nothing to worry about.........., time to put the valve cover back on, and take the tranny out.......
Basket, and clutch components in good shape, does not look to be abused......
Lubricity, ( it did not have a billet basket, you got lucky.....lol)
I hope the bottom end looks as good as the rest........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
NOX
posted March 08, 2008 11:30 AM
All seems good, bearings look to be in great shape, all is tight......., tranny is in excellent condition....., it will look good on my shelf........, time for Blue Moon and Turkey sandwich break........
Now, if it will run like my old stock motor.......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
NOX
posted March 10, 2008 05:06 AM
It lives............, has good oil pressure
Purrs in the garage, lets hope it knows how to growl come Sat testing.........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
zx12mark
posted March 10, 2008 08:24 PM
nox--- how many miles on that engine. how did you check your main bearings-plasti gage
posted March 11, 2008 02:24 AM
OEM 228psi = 12.2:1 (from manual)
i knew i had that # somewhere
NOX
posted March 11, 2008 05:13 AM
Yeah, I had it too........
But when you check it cold, it measures higher.........., we mainly just wanted to see how sound it was before I started pounding the heck out of it.........
Pretty hard to destroy one of these in stock trim.........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
