BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: info on running 2 intake cams ? (12R) NEW TOPIC NEW POLL POST REPLY
posted January 06, 2008 11:12 PM
Im putting Carpenter springs in, so springs arent the issue, the sensor on the end of the exhaust cam is. the notch appears to be in the correct place, but what the hell do i screw it into? im assuming i have to have it drilled and tapped??
one more question, how bad is the intake cam out on timing when its used on the exhaust side?
thx!
posted January 07, 2008 04:12 AM
better off just getting a pair of used muzzy cams. i see em now & then in the classifieds
posted January 07, 2008 04:13 AM
BTW: pull off the cam trigger and you will see how it is secured. pretty easy to set it up on the int side,
posted January 07, 2008 06:29 AM
thx Karl. I kinda thought the Muzzy cams would be a bit much for my build though?
0.25074791908264 seconds processing time
