BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Bearings and Cases for sale CHEAP!!!!! NEW TOPIC NEW POLL POST REPLY
madmike
posted December 31, 2007 11:32 PM        Edited By: madmike on 31 Dec 2007 23:36
I just wanted to caution anyone with a weak stomach to not view these photo's....
just a view of the bearings coming out of my stroker motor finally....
main bearing case surface
same shot closer....
Other side of case surface on main...
bearing on right came out of main
other bearings...
another close up of case main bearing surface, and no it is not an illusion...
thrust bearing surface...
madmike
posted December 31, 2007 11:48 PM
More views...
Main Crank center Journal... surface 1
Main Crank center journal surface 2
Main Crank center journal surface 3 which is 180 deg opposite surface 1???
Bearing from that center journal....
another case shot
another case shot
closer shot of case surface on main journal...
same journal, top case shot
another view of the top...
madmike
posted December 31, 2007 11:53 PM
Outside of center main actual bearing\
and finally another shot of the center main journal surface....
I am not to sure why this happened? and the wear patterns on the crank are very weird to me anyway!
any input?
thanks
MM
posted January 01, 2008 01:24 AM
OUCH!!! what were you doing when that happened? at the track?
wolf racing
posted January 01, 2008 01:43 AM
madmike,
Hell, you should try running some oil in the engine (lol). Not that it's a laughing matter!!!
Those sorts of photos bring a tear to my eyes.
Do you check oil for "gold" after racing? What sump do you run? Anything worth noting in the pick up?
Only seen that sort of torture twice. Once when the pickup was full of 3 bond and once when the sump was shortened.
Just curious as to the history of how it got that way.
Wolf....
Never Ever Give Up
  Ignore this member    Click here to visit Wolf Racing's homepage.
harryzx-12
posted January 01, 2008 05:25 AM
That should buff right out!
starchild
posted January 01, 2008 05:41 AM
hey mike very sorry to see this have a question is this a stroke 12 or a 14? i've stroke my 12 and spun bearings several times but i have never seen that much damage.
jay
Y2KZX12R
CompetitionCNC.com
posted January 01, 2008 06:01 AM
Ouch. Damn.
Mike did you document what the bearing clearances were when assembled? If so look back at your file and see what you had the mains at.
How were the rod bearings?
Is your screen in the pickup clean or is there crap blocking it?
What pan and pickup are you running?
There was a heat issue for sure. But why?
Y2KZX12R
CompetitionCNC.com
aliveagain
posted January 01, 2008 06:10 AM
http://www.flitz.com/index.html
The scary part is you probably didn't hear it! Can anyone add metal to the bearings surfaces and then have it line bored? I would think adding metal for the thrust wear ring would be easy enough.
posted January 01, 2008 06:43 AM
MM, usually when we see a Flat tire we can say it is only flat on 1 side! I cannot say that your bearings are only bad on 1 side!! It looks like sonething got in there and "Started" the Damage then the rest was history
AA. in Car engines where there are oversize bearings, they would assemble and torque the cases and align bore them and put in larger OD Bearings. On Peggy's 911s that has Mag cases this was done several times and I have the last set of 3 over bearings in the world that I got from Tazmania and I Ain't selling!
posted January 01, 2008 08:14 AM        Edited By: entropy on 1 Jan 2008 08:17
Whoa!!!!
great pix, Mike!
alot of folks talk about "spun" bearings when they really mean damaged bearings.
Mike knows how to spin em!
posted January 01, 2008 10:51 AM
Damn bracket racers, your so abusive to the machines!!!
Hey Karl, Mike needs the help from the garage girls
posted January 01, 2008 11:18 AM
that was a 1270 motor wasnt it MM? didnt you used to run a 1375 till issues like above? maybe the cases were warped? just guessing
toddisslow
posted January 01, 2008 11:38 AM
Nice post-mortem images.
Sorry to view your once proud motor, but if you don't break a rew, you're not trying hard enough.
You certainly did apply a new finish to all those once shiny and/or smooth surfaces.
I don't visit this forum often, but I'll presume you're going to rebuild..or rebuild UP perhaps.
Happy New Year and best of success in 2K8.
TRNorBRN6001
posted January 01, 2008 12:54 PM
Dang, MM that really sucks!
How is the top end?
TFA 200MPH CLUB MEMBER!
posted January 01, 2008 01:20 PM
How is the top end?
Ask Mike how long that motor has been longing for attention since he cratered it on Fri before a Texas Shoot out On the bright side, he won prettiest bike on Sat
capt10ed
posted January 01, 2008 03:12 PM
Ouch!!!!!!!
That had to hurt
and 204.5 in the mile.
BrooklynNYZX12
posted January 01, 2008 05:16 PM
Mike,when the engine is squealing,screeching and welding itself together try backing off the throttle!!Thats definitely one of the worst looking lower ends.The Garage Barbies stomachs are too weak for that!
Orient Express Top Street Bike Winner 8-4-07
madmike
posted January 01, 2008 06:35 PM
How is the top end?
Karl is right, this motor has been sitting around for a moon or two... and the top end is great! the pistons, block and head off of this motor took my bike to 196mph at the texas mile in October...
A little background about this motor, it was built strong and run hard, very hard for 2 full years, and well over 1200 dragstrip passes on it. and I ran right behind Osti33 at the texas shootout, and I felt the bearing spin so I shut the bike down right away! but it looks like it had been starting to go bad for a while? I actually was going to drop the motor and put all new bearings in it after this race... and dynoed the motor at Johnnie Cheese the day before this happend, so his dyno probably killed it...
but on the bright side I caught it before it broke a rod, which from the way everything looked was not to far away!!!
madmike
posted January 01, 2008 06:46 PM
the strangest thing to me is the main center journal and how half of it looks great and the other side is beat to shit! I have to think there is something wrong with my crank? the 4 rods that came off were good, so it was only the main's
and the bike had "plenty" of oil and I used to run Kendell GT-1 20-50 oil... and I change my oil every 2-3 races and never noticed any "gold" but I think if I would have sent my oil in to be checked out, I would have probably know something was going bad...
and this was my 1361 ZX12 motor. and I am not sure what I am going to do with what is left yet? up in the air for sure... I have to see if the crank is even any good... if not it will be an easy decision.
and Karl is correct even though the motor was bad... I still took first place in the best looking sportbike!!! they did not make me start it...
and someone has photo's of what the oilpan looked like when we dropped the pan that night, Karl, Ryan?
osti33
posted January 01, 2008 07:57 PM        Edited By: osti33 on 1 Jan 2008 20:00
OUCH!!! I can't beleive you got that motor tore down already. LOL!!
I have the photos of the oil pan.
I'll email them to you. I don't have a place to host them.
osti33
posted January 01, 2008 08:18 PM        Edited By: osti33 on 1 Jan 2008 20:20
Here they are. I looked at the date on them... 4-17-2005 Damn that was a while ago. LOL!! I like the last one where Karl is holding the beer for a size comparison.
Johnnycheese
posted January 02, 2008 04:12 AM
Damm all I can say is I think that Mike better stay off dynos for a bit.
LOL
posted January 02, 2008 05:37 AM
1200 passes MIGHT have had something to do with it...
Mike,
if you were thinking of sending the crank to Marine for "checking", IMO save the shipping costs and mount it prominently in yr garage (a trophy of sorts), or bring it to:
Scrap Processors Inc
306 SE 5th St
Des Moines, IA , 50309-5116
Phone: 515-283-1707
Looks like all 9 journals need repair.
A couple years ago, I sent my billet crank to David and he said junk it rather than have all 9 journals repaired.
posted January 02, 2008 06:10 AM
1200 passes! maybe lol
what about the 5mm stroker option? :d too much $ because of bad mains?
0.49090886116028 seconds processing time
