BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: 1/6 throttle mod? NEW TOPIC NEW POLL POST REPLY
mrsantafe
posted October 12, 2007 04:49 PM
1/6 throttle mod?
/6 throttle mod? Is there one available for our beloved zx12?I was just reading a post on gixxer.com that says there going to the yamaha dealer and ordering the part for roughly 12.00 and adding to there gsxr's. any thoughts???
2006 ZX14 gone
2004 zx10r (her race bike)
2002 ZX12 (still kicking a--)
2007 gsxr 1k (race bike)
mrsantafe
posted October 13, 2007 07:39 AM
anyone???
2006 ZX14 gone
Halvefast
posted October 13, 2007 04:53 PM
I'll take a look at the ZX10 & 636 this week, maybe we have some thing there.
Good idea!
ECTA Ohio Mile 195.132mph
mrsantafe
posted October 13, 2007 05:11 PM
Thanks, I believe this an option for zx10's in kawaski's hipo catalog.
2006 ZX14 gone
shiphteey
posted October 13, 2007 06:00 PM
Don't LOOP it!
Gemini Motorcycles
lietoome
posted October 13, 2007 07:17 PM
Ship, if memory serves me correctly, this throttle set up was designed for roadracing. To WOT, you would actually have to turn the throttle WAY more than just whacking it. It actually turns the throttle in smaller increments?
FWIW--I could be totally incorrect.
Two Wheel Werkz
posted October 13, 2007 08:52 PM
all you need is away to make the cam on the trottle tube bigger, some bikes you can do this using a piece of a tie wrap and some epoxy
Nukedog
posted October 14, 2007 11:14 AM
I have never heard of a 1/6th but i have heard of 1/4 for many years for quicker throttle response but it sounds like you want less?
02 Busa...Turbo...
09 YZF-R6S...
posted October 15, 2007 08:18 PM
A guy on the zxforums was selling 1/4 throttle kits a while back.
burnout
posted October 23, 2007 04:53 AM
Contact these guys. I've got a 1/5th on a 14 and it works for me. Check out the part number on your throttle assembly at Kaw's website to see if it is the same as on other models. If I recall the 14 and the 10 are the same. I don't know about the 12
http://www.doublezracing.com/
1/8 5.66@129.77
1/4 8.74@159.60
Rifleman_duce
Yeah, that's what she said
posted May 02, 2008 05:33 AM
I'm one of the guys at Double Z Racing
636, 6RR, 10R and 14R are the same
6R, 7R, 9R, 12R are the same but different then the above modles
Install is the same for all the Kawi bikes... just PM me, I'll get you all the info.
]Need to know how to install your Rifleman's 1/5th throttle insert? click me
For more info on a sticky grip (not enough cable slack) click me
  Ignore this member    Click here to visit Rifleman_duce's homepage.
SteddyTeddy
posted May 04, 2008 04:54 PM        Edited By: SteddyTeddy on 4 May 2008 17:55
How much for the thottle mod?
psycho1122
posted May 06, 2008 05:26 AM
Yoyodyne seems to have racing throttles?
ninja12
posted May 07, 2008 12:04 PM        Edited By: ninja12 on 7 May 2008 13:04
There is a R1 stock throttle handle that does the same thing for less than $20.
Rifleman_duce
posted July 10, 2008 01:16 PM
yes, the R1 grip will work, it is about 3/8ths of an inch shorter the the kawi grip and there will be a gap between the end of the grip and the bar end weight. the rubber will also be different. If you don't have a problem with that (track bike) then the R1 grip is the way to go.
the inserts mentioned above fit inside the OEM housing, on the OEM grip so the original asthetics are maintaned.
Most of the Race throttles are even shorter 1/6 or less and require a custom housing and cables (that's why they are significantly more expensive).
PM me if you have more questions. I can get you hooked up.
Halvefast
posted July 10, 2008 03:11 PM
Rifleman's cam works great, really quick to install,
just heavy on the wrist for long rides if you don't have a cruise control
Otherwise great addition, took total of 30min. to install
shane661
posted August 24, 2008 01:05 PM
Which year R1 grip tube works?
shane661
posted August 25, 2008 05:15 AM
Bump on this question, I am head to the Yamaha dealer tonight.
0.23864603042603 seconds processing time
