BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: how to not damage? NEW TOPIC NEW POLL POST REPLY
twista
" Get up, and Stay up ! "
posted March 22, 2007 07:29 PM
how to not damage?
dont want to damage any internals while trying to swap front sprocket on my 12,, first off,, does this thing come off counterclockwise or clockwise,, next what can be done to remove it,, ie. impact with nothing,, ,, or wedge some wood into the sprocket,, or wheel,, cmon give me something,, my radiator and sprocket are gonna be here soon,, and i need to know.. thanx
posted March 22, 2007 07:42 PM
probably the easiest is to put a board between the rim and swingarm... and yes counter clockwise =off... make sure that the brass washer is FLAT!!!! all the way around the nut... and yes you can use an impact to take it off.
Wideout
posted March 22, 2007 09:02 PM
+1. Wood and impact.
NOX
PMRA / TMRC Super Street 4022
posted March 24, 2007 02:25 AM
with the bike in neutral..........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
Y2KZX12R
CompetitionCNC.com
posted March 24, 2007 02:40 AM
Thats a MUST.
Make damn sure its in neutral. I've seen tranny gears broken more than once from using the tranny and engine to hold the output shaft from turning while using an impact.
In neutral and with a block of wood in the wheel works well with an impact gun.
Y2KZX12R
CompetitionCNC.com
shane661
posted March 24, 2007 09:59 AM        Edited By: shane661 on 24 Mar 2007 11:00
Hey, just a question...
What is the point of putting a block of wood in the wheel if the bike is in neutral?
I used a block of wood, with the bike in 1st, and a breaker bar...is that dangerous?
I can't imagine that my arm loads the trans more than 175 hp does...
posted March 24, 2007 12:47 PM
i do not think it is dangerous if you apply constant pressure, I would not use an impact with it in gear... but if you are using a breaker bar. I would think it would be ok...
zrexpilot
posted March 25, 2007 03:40 PM
neutral and an impact and you wont need any wood to hold the tire
ZXLNT
posted March 25, 2007 09:30 PM
And just have someone hold the rear brake.
posted March 27, 2007 07:17 AM
exactly.
I hit mine this morning with my impact. It had a loose chain and I didn't even bend back the lockwasher. Buzzed it right off.
Torquing it back on is another story...
NOX
posted March 27, 2007 08:57 PM
Listen to Karl..........., if it can be broken, he has done it three ways............
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
zrexpilot
posted March 29, 2007 06:49 PM        Edited By: zrexpilot on 29 Mar 2007 19:50
exactly.
I actuall just buzz it back on with the impact. I think some things just arent that critical and dont require the torque wrench to be brought out. heard a few horror stories of people using a torque wrench, like a ZRX dude who torqued his oil drain plug on in ft-lbs instead if in-lbs, can you say stripped. LOL
rgeorge
posted March 29, 2007 07:35 PM
I used that method the first time I changed my front sprocket. The bike was on the rear stand at the time. I had to pull HARD on the breaker bar. When I got it to break free, the rear stand shifted and the bike fell on me.
Now I use the impact method with the bike on the ground.
SteddyTeddy
posted March 30, 2007 10:55 AM
1/2" air impact!!!!!!!!!!!!!!!!!!
0.28093600273132 seconds processing time
