BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Attention Doug Meyers NEW TOPIC NEW POLL POST REPLY
cowboy
posted May 23, 2002 02:33 PM
I have a Muzzy airshifter that isn't shifting reliable.My dealer(Maple Ridge Motorsports)said they talked to you and you mentioned that noone else was having problems and to use co2 instead of nos.Well my setup requires me to use nos to active the shifter and this kit is supposed to work fine with nos.The shifter will allmost never shift in the burnout box and there is plenty of kill.Do you have anymore ideas before i give it back to the dealer?I'm trying to run nos and don't want to be missing shifts thats why i purchased the most EXPENSIVE kit out.
ZRXDean
posted May 23, 2002 03:41 PM
This might get you in touch with Doug a bit quicker cowboy. Hope you get it figured out.
Doug Meyer-
541.385.0706 ext 102 office
doug@muzzys.com
RAC4IT
Bergie
posted May 23, 2002 05:19 PM        Edited By: RAC4IT on 23 May 2002 18:20
Ditto
Except I'm using C02. Same situation.
cowboy
posted May 23, 2002 06:17 PM
Doug Meyer-
doug@muzzys.com
Thankyou,I'll try to call him also
kcadby
posted May 23, 2002 06:41 PM
We've been running NOS in John's shifter for months with NO problems (since I shimed the regulator)...
We DID have problems with the relay "freeking out" (clicking when touched or moved) until I just "let it hang loose by the wires"
I also moved the switching valve under the fuel tank to shorten the air-line to the shift cylinder AND lengthen the supply line hoping to have more volume "ready to go to the shifter" instead of having to wait for the regulator to "react to the demand" could ALL be BS but...it WORKS!!! TROUBLE-FREE!!!
cowboy
posted May 23, 2002 08:32 PM        Edited By: cowboy on 23 May 2002 21:40
Kcadby,Thanks,at least i know it will work with nos.Do you have the piston bracket mounted exactly 2 1/2 inch on the shifter linkage?So your saying you have a line between the regulator and the relay?My picture showed the relay tapped right into the regulator?
johns
posted May 26, 2002 05:29 AM
muzzy air shifter
We installed my Muzzy air shifter 2 weeks ago and it is working flawlessly on co-2. I am slowly setting the time delay for shorter delay to find where the line is. The only problem I had was finding a supplier to fill the 1 lb bottle with co-2. After a local welding supply house charged me $30.00 to fill it I got pissed off and purchased a 60# co-2 cylinder and a high pressure (3000#) hose to fill
my own. You also need a good quality electronic scale if you are going to do this. I didn't want to arrive at the track and find out that due to a small leak I didn't have enough co-2 to operate the shifter. I am looking around for a small liquid filled high pressure guage to install between the bottle and the regulator.
2006 ZX-14 (sold)
2012 ZX-14R (Brock's Perf. project bike Louisville Slugger)
2013 Honda VFR1200F
2003 124 C.I. H.D. Super glide
cowboy
posted May 26, 2002 10:30 AM
Thanks for the reply John.I think the next thing I'm going to try is mounting the regulator,solenoid assembly down closer to the shift piston so it shortens up the air line(as Kcadby suggests).I'm going to try and get ahold of Doug tomorrow and see what he thinks.
RAC4IT
Bergie
posted May 27, 2002 03:59 PM
Holy S***! I pay $ 1.25 to have mine filled at a local PaintBall shop.
cowboy
posted May 27, 2002 05:46 PM
I'm in the same boat thats why I "t"off of my nos bottle.Went to the paint ball place but they could only do the top refill bottles.
0.26297092437744 seconds processing time
