BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: pipe springs NEW TOPIC NEW POLL POST REPLY
aliveagain
posted February 06, 2007 03:15 PM
pipe springs
I just got the new pro pipe today and have it in place.I went to install the muffler springs and the bottom one is loose.The top one is fine but I can assemble the bottom by hand.I swapped out with the other springs but get the same results. What are my options?It'll look kind of bush if I just safety wire the bottom together.Is there anyway to shorten the springs?
posted February 06, 2007 07:39 PM
not that I know of, unless you want to bend the hook shorter....
oldkawboy
posted February 06, 2007 08:13 PM
AA,
I noticed the same thing on my pipe but figured since I'm just hanging it from the garage rafters for now, it was just because it was not mounted on the bike and pulled....I dunno???
Dan
aliveagain
posted February 07, 2007 09:14 AM
I ended up bringing the midpipe to work and had sheet metal guys grind off the tab.They tig welded it back on about1/2" back.There was a full page disclaimer that came with the pipe so I wonder if these were rejects.Still not a bad deal provided you have the resources to make right.
posted February 07, 2007 11:37 AM
same thing happened to mine, and dave t sent me another spring. Just as loose, so i put a Brock spring on it
aliveagain
posted February 07, 2007 12:40 PM
I knew it wasn't the spring because I had tried several others that were on the pipe.
RobMuzzy
posted February 15, 2007 02:46 PM
If any others have this problem we will gladly fix it.
oldkawboy
posted February 15, 2007 06:49 PM
What do we need to do Rob?
Dan
0.2216329574585 seconds processing time
