BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: nitrous distribution block NEW TOPIC NEW POLL POST REPLY
aliveagain
posted January 15, 2007 08:05 PM
I have a leak somewhere in my system and am looking to clean up the connections.I was thinking of using a distribution block to tie in all the systems together.Right now,I have the bottle feeding the shifter,a 40 shot spray,a remote gauge and a pressure sensor for the heater.Way too many fittings and it loosens up all the time while changing the bottle.How does everyone else tie these together and do they use a block?
ninja12
posted January 16, 2007 09:04 AM
That sounds like you NEED a block,
I would make sure that the nitrous path to the 40 shot was straight as possible
to maximize the liquid flow.
aliveagain
posted January 16, 2007 01:10 PM
I may try to make one tomorrow.If I make the port to the 40 shot directly across from the inlet supply,that ought to give it a straight shot.thanks for the reminder on that.
ninja12
posted January 17, 2007 05:13 AM
You could leave what you have in a secure spot and add a extra 12" line to the bottle.
That way nothing else gets moved when you change bottles.
aliveagain
posted January 17, 2007 09:04 AM
where can I find a short line like that?I found my leak also,4 cracks around the inlet base of the regulator for the shifter.I must of tightened the fitting too much trying to seal it.
ninja12
posted January 17, 2007 11:11 AM        Edited By: ninja12 on 17 Jan 2007 11:14
I'll bet schintz has them.
Check ebay also.
http://cgi.ebay.com/ebaymotors/NOS-12-inch-4-AN-Braided-Nitrous-Hose-Line-NEW_W0QQcmdZViewItemQQcategoryZ33740QQihZ001QQitemZ110079231671QQrdZ1
I also saw 18 inch, search " nitrous line "
0.42431592941284 seconds processing time
