BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: I heard a noise in the garage NEW TOPIC NEW POLL POST REPLY
Johnnycheese
posted October 21, 2006 12:13 PM
it sure sounded like a big 12 running.
well what's to know TRNBRN is running
Wideout
posted October 21, 2006 01:11 PM
Most excellent. Karl and I made pretty big progress today too.
osti33
posted October 21, 2006 02:12 PM
SWEET!!
posted October 21, 2006 05:38 PM
Go - Johnny - Go, GO!!!!
TRNorBRN6001
posted October 21, 2006 08:49 PM
Went through a few heat cycles, JC took it for a little test run down the street and rips a darky off up the drive way. I am sure his wife will not be pleased when she sees it. I could not resist so I took it out for a little spin down and back JC's street. IT'S A FREAK'N BEAST!!!!!!!!!!!!!!!!!!!!! Unbelieveable!!!!! This is what the 12 should have felt like from the factory.
..........................And it has not even been tuned yet, crazy!!!!!!!! especially with all the mods, fuel pump, exhaust, motor, cams, TBs, ect................
This thing has some massive low end grunt and it's not even built that way!!!!!!! I don't think I even came close to 4-5 grand on the tach.................. I was too scarred!!!!!!!!!to whack the throttle in first so I think I was putting along and did it briefly in second or third. It just shot up and went!!!!! I definatley got a few evil eyes from the neighbors.
Looks like Dyno day will be this comeing week and then a nice break in procedure at the Mile.
Nothing like a heavy hit of CHEESE MAGIC!!!!!!
TFA 200MPH CLUB MEMBER!
TRNorBRN6001
posted October 21, 2006 08:52 PM
Entropy, WideOut, give us the scoop!
posted October 22, 2006 02:24 AM
Woo-HOO, Gary is back in the saddle; tells ur mods!
You gonna juice it at the Mile??
Where are you gonna dyno it?
Matt & I were doing set-up stuff yesterday, changing gearing, etc. I put on a stock arm (thanks for the loan Gerard!)
My motor is running sweet. I'll put a few street miles on it today, prolly take it to the dyno on thurs am.
osti33
posted October 22, 2006 07:38 AM
Karl and Gary, you both have PM's.
Thanks,
Ryan
TRNorBRN6001
posted October 23, 2006 06:55 AM
Shot ya a PM Ryan
Juice: Maybe a little juice (progressive 70 shot)
Dyno : Builders house later this week, his neighbors are going to be pissed!!!!! Hope the dyno still works and putting it back together can't be too easy either.
Everything on my 00 ZX-12:
Marine Crank
60mm Stroker, micropolish, nitrided, and balanced
Falicon Rods
Falicon knife edge
Robinson Industries
Under cut trans, micro polished, WB Ceramic Bearings, and Over Drive
gears
Millennium
Cylinder Block Magnaflux, bored to 86mm, honed, and nicksil
JE Pistons
86 mm 13:1 pistons
Ceramic coated dome, tool steel pins, and coated skirts
APE
HD cylinder head studs
Carpenter
Ported and polished head, Ferrea SS valves, Muzzy HD valve springs, titanium
retainers, polished and coated cam caps, Ceramic coated combustion
chamber, and exhaust port. Cheese magic, assembly and valve job.
Muzzy
Race Intake and Exhaust Cams (Int. Lift 10.2mm Exh. Lift 9.9mm, Duration:
253@ 1mm. Degreed to JC specs
Orient Express
2mm Overbore Tappered 48mm Throttle Bodies and SS butterflies
Bear Racing
Modified Billet Velocity Stacks (Purple, fits like a glove) Thanks Mr. Hill
Muzzy
High Pressure fuel pump (350 lbs. per Hour @ 50 psi.)
Muzzy
Pro Nitrous Stealth System, 5lb NOS bottle on passenger peg
Schnitz
Nitrous Controller
Schnitz
EFIR
Muzzy
Pro Pipe SS Race 4 into 1 Exhaust system, ceramic coated header (12 lbs.)
Schnitz
HD clutch springs
Muzzy
Clutch Basket
Muzzy
Clutch Hub, HD Plates and Fibers
Muzzy
Air Shifter and Digi Fuel Kill Box
BMC
Filter
Scotts
Steering Stabilizer
ART
Carbon Fiber Monster Scoop, Ram Air Ducts
WorldBearings
Ceramic Wheel Bearings
Muzzy
Three inch extended and polished swingarm
Galfer
Brake Wave Rotors, front and rear
Michelin
Pilot Power Tires
Front 120/60ZR-17 Rear 190/50ZR-17
Power Comander
PCIIIR
JohnnyCheese Performance
Extra Heavy Hand Of Cheese Magic Added
psycho1122
posted October 23, 2006 07:19 AM
You forgot to mention the "Kitchen Sink"!!!
posted October 23, 2006 07:43 AM
Holy Crap!!!! dude I thought I had a lot done to my bike... WOW!!! I am going to talk with you about the cam caps... when I get to TX...
posted October 23, 2006 08:53 AM
new wrist pin circlips too? !
sounds like a wicked machine,
be nice to see the dyno #'s when you get em!
GUNNER
posted October 23, 2006 08:58 AM
Damn!! That's a stack of cash that a show dog couldn't jump over
posted October 23, 2006 09:00 AM
Geezus, Gary, you went the WHOLE 9 yards! (ceramics in the trans???)
I can't wait to see it run.
BTW: when you do the dyno pulls, pu-leese bring the motor up to FULLY heat soaked before doing any full rpm pulls... Just a thought...
TRNorBRN6001
posted October 23, 2006 09:02 AM
Thank You MM for all the parts.
I'll post the numbers as soon as know. I think the C/R is a little lower for the street and Nos, but it still feels strong. Now I just need to loose 40-50lbs!
0.21638298034668 seconds processing time
