BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Musical Cams NEW TOPIC NEW POLL POST REPLY
megabyte
posted July 12, 2006 04:28 PM        Edited By: megabyte on 12 Jul 2006 17:59
Musical Cams
I know we've been round and round on this subject, but when the music stops, what cams do I want for my 1361? I know the quality is there, but $1370 for Muzzy's feels like a gouge....
Thanks,
supra5677
posted July 12, 2006 04:50 PM
call delta cam and get them grinded..
Ide go .381 lift on the intake same duration and .369 on the exhaust same duration. To get the most out of cams you MUST extend the rev limit..
supra
megabyte
posted July 12, 2006 05:02 PM        Edited By: megabyte on 12 Jul 2006 18:07
supra
My rev limit has been increased by 600 w/the ECU mod. Is that enough? Also, what Cam timing would you recommend, would you go w/heavier springs?
Thanks for your help!
osti33
posted July 12, 2006 05:27 PM
You need heavier springs with aftermarket cams.
The Muzzy cams come with the proper springs, adjustable sprockets, and ti retainers.
NOX
PMRA / TMRC Super Street 4022
posted July 12, 2006 06:28 PM
Can you gain anything by extending the rev limit on a stocker? How much? Reliability????
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
supra5677
posted July 12, 2006 07:04 PM
640 more is where mine is now... If ridgeracer is successful with his project Ill max out at 1000 more than stock.. To answer you question yes...
supra5677
posted July 12, 2006 07:06 PM
keep in mind that strokers can't safely rev as high as the stock 55.4 mm stroke.. 600 more than stock is plenty.. probably 10-15 rwhp.. Since you do have a stroker you could probably add a little duration, but I think the stock duration is fine... you might want to ask Y2K
supra5677
posted July 12, 2006 07:07 PM
you can gain mph by adding rev limit on a stock cammed bike.. but not horsepower.. To add horsepower you have to degree your stock cams or go with bigger cams.. but do LOTS of homework before you make changes..
NOX
posted July 12, 2006 07:16 PM
IF you gain mph, you have to gain et..............
Has anyone done this, results at the strip?
Who makes it? Cost??
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
supra5677
posted July 12, 2006 08:08 PM
you will gain mph but not horsepower on a dyno... BTW.. With the extended rev limit ecu I spun a dynojet 150 to 200mph plus and it was shut down by the dyno brake.. The horsepower didn't increase it just held the power longer...
megabyte
posted July 12, 2006 10:27 PM
Wow so much great advice.
osti, sounds like you might think the Muzzy system is the way to go? Is it the package deal w/matched components? I already have the adjustable cam sprockets, and I can get my cams grinded for a lot less then $1370. Are the springs and ti retainer that expensive?
supra, the delta cams idea is one I'm going to pursue. I do think osti is right about the springs, and ti retainers etc. What centerlines would you recommend. Muzzys uses 105/107.
Thanks,
posted July 13, 2006 03:45 AM
Mega,
I just had Webb grind me some cams for $660,
NOX
posted July 13, 2006 04:31 AM
Where can I get the extended rpm from?
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
megabyte
posted July 13, 2006 09:54 AM
Mega,
Entropy, would you mind sharing what specs they ground yours to?
Thanks,
osti33
posted July 13, 2006 01:35 PM
Megacycle cams will also re-grind your stockers if you want to go that route. You will still need to buy heavier springs and ti retainers.
supra5677
posted July 13, 2006 02:02 PM
the stock zx12r and zx10r springs have 35 pounds of seat pressure.. NOT enough for aftermarket cams you need 50 pounds of seat pressure.. So yes change your springs..
supra
NOX
posted July 13, 2006 03:04 PM
does kmotion make them?
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted July 13, 2006 11:21 PM
supra
are you sure about the stock = 35?? seems way low. 60-65 is where many folks have been running with agressive cams.
posted July 13, 2006 11:26 PM
Call Dave Owen (DaveO on SH.org) in Mass. He's the guy who recently ran 220mph NA at Maxton.
508 802 0425
make sure and tell Karl sent you!
NOX
posted July 14, 2006 04:58 AM
Thanks Karl...........
where u at in the world these days?
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
supra5677
posted July 14, 2006 05:12 AM
pretty sure stock is 35 seat pressure.. As far as extended ecu there is a guy that does it for 200 on this board forgot his name. SBM way over priced at 600.00.. I would wait for ridge racer if possible..
supra
blueshark
posted July 14, 2006 05:49 AM
Drag Bike Direct extends the ECU's, I think it's 200 or 250? I haven't used them, just saw someone talking about it on Psycobike.
http://www.dragbikedirect.com/
posted July 14, 2006 12:15 PM
in case you missed it above
508 802 0425
make sure and tell him Karl sent you!
osti33
posted July 14, 2006 12:22 PM
508 802 0425
LMAO!!!
TRNorBRN6001
posted July 14, 2006 01:20 PM        Edited By: TRNorBRN6001 on 14 Jul 2006 14:21
Yep, Dave O is da Man for the job. By the way you can increase HP on a stock bike with
an extended ECU, just add a little juice.
There is no doubt Muzzy is proud of their products. Shnitz has some springs if your
looking to save a little money, then you can just have them cams welded on and
reground. Ya might want to consider SS valves since ya got her down. I am sure
Mad Mike has some laying around.
TFA 200MPH CLUB MEMBER!
0.23965096473694 seconds processing time
