ninja12
posted May 04, 2006 08:11 AM
eliminate oil cooler.
After a bad blow bearing material everywhere
I'm afraid that the cooler may be compromised.
This is a track only bike so i'd like to eliminate the
very expensive cooler for this and future rebuilds.
It looks like muzzys relocator kit eliminates the cooler
but i don't really want to relocate the filter.
Any ideas or suggestions?
Why don't someone come up with a cooler flushing service?
I'm sure something could be designed to back fush these things .
MUZZY, APE, SPENCERCYCLE who's up to the challenge?
your car is slow
Fuck Nitrous...Got Boost?
posted May 04, 2006 12:30 PM
while i dont recall off the top of my head when I removed mine...but couldnt you just remove the cooler and screw the filter directly to the block?
Thats how it worked on my old LT1 anyway
buddy
posted May 04, 2006 12:36 PM
The oil cooler on my 01 ZX12 track only bike has been eliminated. I use a NAPA gold 1381 filter which goes right where the cooler was. Adams performance did the change and it works well. I also have the cooler available.
NOX
PMRA / TMRC Super Street 4022
posted May 04, 2006 01:23 PM
Buddy, do you run a dry sump?
What is the purpose in removing the cooler?
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
zxboy
posted May 04, 2006 01:36 PM
I'm interested too.......The cooler is heavy and there is the extra coolant plumbing. So Coby did the removal for you ???? or did you figure out what filter to use ???
NOX
posted May 04, 2006 02:08 PM
and, how much oil does this take out of the system......., never heard of doing it unless using a dry sump....
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
zxboy
posted May 04, 2006 03:12 PM
Edited By: zxboy on 4 May 2006 16:12
Never thought about the loss of oil capacity....maybe a half quart max ??? but that's not a issue for me. I've got the Coby pan with 5 Qts capacity
buddy
posted May 04, 2006 05:44 PM
I had Coby install a motor he had built into my 12 and the oil cooler was missing. It had one of his pans on it and I have never had any problems due to oil. I only use the bike on the strip, tho, and don't know if it was used on the street also if there could be any problems. His pan uses about a quart more than stock, even with the oil cooler gone. The filter seems to be very well made and works excellent. I became more aware of the construction of filters due to the article on filters and oil that redelk wrote sometime back.
NOX
posted May 04, 2006 06:13 PM
So it does not affect performance either bad or good.........., I thought it may be some trick you had............
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
buddy
posted May 04, 2006 06:19 PM
I don't know if it affects performance or not, as I have not ran this bike WITH a cooler. I never asked Coby why he removes the cooler, but maybe there is a reason other than the loss of weight. He's the motor builder and a good one. I just accept that he probably has a good reason.
NOX
posted May 04, 2006 06:40 PM
Maybe clearence issues? Or able to run a bigger filter?
I may call them and pick thier brain a little............
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
ninja12
posted May 04, 2006 07:20 PM
Edited By: ninja12 on 4 May 2006 20:30
i'll bet you will need some type treaded pipe to attach the filter.
Thanks buddy.
you have a pm.
posted May 08, 2006 12:10 PM
Remember the Oil "Cooler" is more like an Oil controller. Once the Oil heats up, (Which it also helps to do) then it Stablizes the Oil Temp
ninja12
posted May 09, 2006 11:49 AM
Why is that important.
If the bike is warm the oil will be warm. right?
