BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: zx10 lockup NEW TOPIC NEW POLL POST REPLY
1969ca
posted May 03, 2006 09:38 PM
zx10 lockup
what are your thoughts new t the drag racing on a bike but have gone 9.82 at 142 it just that the oem clutches are very pricey and if i went to a lockup wold they last longer woul i see better 60ft and top end speed thanks for any help
NOX
PMRA / TMRC Super Street 4022
posted May 04, 2006 03:43 AM
Only if it is tuned correctly
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
kcadby
posted May 04, 2006 08:38 AM
Yes to all.
We will have one in a 10 this week...
You can "shim" the springs for now if need be...
salsa1
posted May 04, 2006 04:34 PM
where would ya buy the shims? local hardware or autoparts store and what size if you know...
anyone bought them and tried them.. ..
Salsa1
NOX
posted May 04, 2006 06:11 PM
MTC
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
1969ca
posted May 04, 2006 07:37 PM
how far do you shim your springs went to mtc didnt find shims must be looking in wrong space
kcadby
posted May 05, 2006 10:11 AM
You need to call MTC...they wouldn't be listed as a normal sales part...
I had several shims left over from other LockUp installs...
You can add as many as you feel you need as long as the springs don't coil bind when you pull the lever in...
I am installing this ZX10 LockUp tonight and can post how many shims we have under the springs after I see them...
I very seldom remember details like this until I have done it several times (at least 3)
This bike has run 5.70s and 8.70s with stock motor and our DryShot system...but the mph is lower than it should be in the 1/4...
We will see how he does tomorrow with the LockUp...
salsa1
posted May 05, 2006 11:22 AM        Edited By: salsa1 on 5 May 2006 12:26
MTC has 10 thousands,25 thousands and 50 thousand of an inch thickness for sale.
MTC techline 321-636-9480 Part # KSL105 25/1000"
Part # KSL106 50/1000"
Salsperson said just need to avoid bindind as mentioned by KCADBY. Not sure what to buy yet; $16.00 set ; My local bolt and nut specialist store might have washers that work; also been told spark plug washers work. Still undecided but might get the 25 i/1000 inch as they are close to spark plug washer thickness...
Just a single 25/1000 " washer does not make too much difference as per tech help at MTC ; adds about 2-3 more lbs. per spring; maybe thats enough.. don't know yet.
I gather the lockup clutch is pricey probable overkill for non turbo or no nitrous; not so sure a near stock ZX-10R would really need..they cost over $600.00 I think..and are they streetable..
Salsa1
salsa1
posted May 05, 2006 12:11 PM        Edited By: salsa1 on 5 May 2006 13:14
Found this piece of info digging around the net ; sounds good to me... seek and ye shall find...
"025. shims under each clutch spring, 45 passes, 1.43- 1.52 60' 200lb rider, 15/41 gearing"
also
" welded up my clutch hubs. Which loses the slipper clutch but i have noticed my clutches last alot longer while drag racing. I usually do 10-15 passes a weekend. Several weekends in a row."
For a ZX-10R...would have to look into the welding clutch hubs deal but the shim height question is answered ; should be a safe try anyhow...
Have fun!!
Salsa1
NOX
posted May 05, 2006 12:26 PM
I use the 10 thou on my 12, it gives you so much fine tuning, and you can always stack them.
When you get it in the sweet spot, 1 or two pounds of pressure is huge.................
tuning the arms is huge as well..........., have fun..............., get a cordless drill, keep it charged, you will become intimate with taking the cover off...............
It is worth it though........., it is all trial and error..............
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted May 05, 2006 01:38 PM
Hey Nox.. does that thing launch like butter now???
kcadby
posted May 05, 2006 06:15 PM
TOLD ya I don't remember details until repeated multiple times
The ZX12/Bbusa LockUp washers won't work...sorry I told you they would...
Now that I saw this ZX10 clutch appart again...I remember that...I found washers of proper OD and turned the inside on lathe to fit over the Spring Cups...
They were probly .060 thick and still were not enough to hold the NO2 power...even with new plates...
I used Spark Plug washers all the time MANY years ago before ANYONE made heavy duty springs for ANY bikes...
Hard to believe Schnitz doesn't carry HD springs for the 10 yet?!?!?!
NOX
posted May 08, 2006 05:07 AM
Yes, butter...........
Oh so smooth and consistent............, and my worst light was a 560 this sunday, before that, 524 was my worst. the rest were 5 teens.....
It picks the front wheel up about 60 ft out about 5 inches, for maybe 10 ft, then sits it back down oh so nice.......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
0.22558903694153 seconds processing time
