BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: brock clutch springs NEW TOPIC NEW POLL POST REPLY
wezze93
posted April 28, 2006 09:53 PM
i have a lock-up in my 12 an i was burning up clutchs fast do u thank the heavy springs from brock will help me
  Ignore this member    Click here to send wezze93 an AIM message.
posted April 29, 2006 06:37 AM
sounds like your lock up needs tuning to me....do you have a bunch of weight on the arms?
from what I have heard you need the lightest springs possible to work correctly....
Mad Mike
NOX
PMRA / TMRC Super Street 4022
posted April 30, 2006 03:21 AM
what motor combo are you running, you have it set up wrong...........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted May 01, 2006 01:07 PM
The Idea of a Lock up is to "AVOID" Using Heavy springs so you can control slipping of the line with the lever and the weights will "Lock UP the Clutch" so you will NOT burn up the plates and not have ANY Slipping.
wezze93
posted May 01, 2006 08:11 PM
I HAD LIGHT SPRINGS AN WEIGHTS ON ALL MY ARMS AN IT STILL BURN CLUTCHS. I HAVE TRIED ALOT OF SET UPS AN THE SAME THANG HAPPEN .IF I TAKE WEIGHTS OFF THE CLUCTH WILL SLIP. AFTER THE 60FT. MARK IT WHEELE REAL BAD
NOX
posted May 01, 2006 08:21 PM
Is it a multi or single stage................., how many arms..................
are you throwing the clutch away?
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted May 02, 2006 12:23 PM
Any clutch will burn up if ridden a lot and no cool down time
wezze93
posted May 02, 2006 07:07 PM
its a single stage an i dont ride it on the street
NOX
posted May 02, 2006 07:40 PM
Do you throw the clutch away, or slide it? How much static pressure are you running?
How many arms, how much weight?
How much hp, how much tq, what is your launch rpm..............
I throw the clutch at 7 to 7500, and mine last forever...............
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
wezze93
posted May 02, 2006 08:03 PM
6 arms no wt., 350hp 6000 rpm i throw the clutch away it a turbo
NOX
posted May 02, 2006 08:24 PM
What springs are you running? What is your static pressure?
Send me a pm..................
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
wezze93
posted July 28, 2006 08:58 PM
what is a good static pressure?
NOX
posted July 29, 2006 03:05 PM
Depends on what hp you make at that rpm........
what are you running now.............?
What springs.?
How much do you weigh? all this plays a factor........, is it slipping at gearchanges, or starting line?
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
0.24912905693054 seconds processing time
