BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Solenoid wiring? NEW TOPIC NEW POLL POST REPLY
yzfone
posted March 28, 2006 05:30 AM
Solenoid wiring?
Where is the best place to draw power from for a nitrous solenoid? It will be run through a relay, but I just want to know where you guys are getting the power from.
your car is slow
Fuck Nitrous...Got Boost?
posted March 28, 2006 06:48 AM        Edited By: your car is slow on 28 Mar 2006 06:48
its been awahile...but I think i pulled mine from the power feeding the pc3 at first....then I ran a line down to the + post on the battery. (relay fired off the ground anyway)
yzfone
posted March 28, 2006 07:45 PM
canadamaxxer
posted March 29, 2006 04:15 AM
I would go directly to the battery....run an inline fuse approx 6" (20A I think) from the battery so that the circuit has protection and run 12 or 14 ga wire minimum. I tried to use the PC3 power to run just my Schnitz window switch and progressive controller and it ended up scrambling the pc3's programming. Solenoids draw a fair bit of power and are quite "Dirty" as they come on.....
0.24788999557495 seconds processing time
