BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Race engine Break-in NEW TOPIC NEW POLL POST REPLY
ninja12
posted January 10, 2006 08:05 AM
Poll Question:
How do you guy break-in a new engine for a Track Bike.
I need it to run strong and last one season.
Wild guess 200-300 nitrous passes before rebuild.
Poll Results:
 3 votes (18%)
100 easy miles
 2 votes (12%)
500 street miles
 1 votes (6%)
1000 street miles
 5 votes (29%)
3 heat cycles
 3 votes (18%)
1/4 mile break-in
 3 votes (18%)
other
NOX
PMRA / TMRC Super Street 4022
posted January 10, 2006 09:12 PM
I broke mine in as the factory stated, it hit the track with 1004 miles........
My mechanic, MMI grad, said for a stock motor, that is how it should be done, but, I know others have different opinions....., but some others have not run 124 mph in the 1/8th, with the small amount of mods I have either................
200 to 300 passes on dope is ALOT
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
ninja12
posted January 11, 2006 02:46 PM
All passes won't be on the bottle, but i won't be tring to save it either.
124mph without going inside the motor?
RAC4IT
Bergie
posted January 11, 2006 03:14 PM
His bike is 10 feet long
your car is slow
Fuck Nitrous...Got Boost?
posted January 11, 2006 03:36 PM
stock motor with a turbo or spray is still a "stock motor"
Do not taunt happy fun ball!
ninja12
posted January 12, 2006 07:49 AM
very true
johnnycheese
posted January 12, 2006 08:58 AM
all motors I have EVER built get 3 heat cycles
posted January 13, 2006 08:48 AM
Anytime I put in new rings I use SA Rated 30 wt oil for about 50 miles. Not hard use but on the gas and off the gas between 4 to 7,000 RPMS. Then change to the cheapest Bike Oil and hard Bursts between 4 & 7,000 up to 100 miles. Then try to get another 100 Miles on the bike before racing and if possible close to 500 miles then change Oil to the Motul and down to business. It is very hard to get rings to seat with the Newer Oils nowadays
posted January 15, 2006 03:31 AM
VH,
that seems like a bit much to "seat rings" on a motor with nikasil coated cylinders. I was under the impression that very little "seating" takes place (with today's hard rings + nikasil) ??????
"Back in the day" with softer rings and cast iron cylinders, it seems things were different???
Am I all wet??
I do 3 heat cyles and point 'er down the track, and ALWAYS my 1st passes on a new motor are the best that the new build ever makes.
osti33
posted January 15, 2006 09:59 AM
Am I all wet??
Not wet at all. I do the same thing.
You are exactly right about the nikasil(sp) cylinders.
posted January 17, 2006 01:31 PM
ENT, they do have to seat and even with using the Bottle Brush and dry start up (for the Cylinder) if they do not seat, you will not have a great engine.
NOX
posted January 17, 2006 06:23 PM
I meant WITHOUT power adders........, a turbo in all forms of racing is considered a power adder...........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
NOX
posted January 17, 2006 06:24 PM
Yeah, I can send you copies of the time slips.............
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
kawachan
posted January 17, 2006 08:39 PM
Ride it like you stole it....straight off the work bench!! It is a RACE bike right.......!?!
RED NINJAS RULE!!
posted January 18, 2006 01:49 AM
chan,
you got that thing making noise again??
kzz1
"Show me whatcha workin with"
posted January 18, 2006 04:58 AM        Edited By: kzz1 on 18 Jan 2006 05:35
my motors goes from the surgery table straight to the dyno then the track with no ill effects.
kawachan
posted January 19, 2006 09:08 AM
ALMOST Karl....ran out of time and had to head your way. Sitting in Temple as we speak.
RED NINJAS RULE!!
ninja12
posted January 20, 2006 06:53 PM        Edited By: ninja12 on 20 Jan 2006 19:32
Thanks guys, didn't really see what we are breaking in on a rebuild.
rings don't really wear in like they use too, bearings don't need to breakin unless you are a little too tight. same trans and head. So what is actually breaking in?
Not talking about new bike, just rebuilds.
my 5 steps to break-in within 24 hrs
1. 5-10 mile test ride too check for leaks and noises. 8hrs cool down
2. 30 miles to work , 4 hrs cool
3. 20 miles lunch ride , 4 hrs cool
4. 40 miles home (long way)
5 . oil change and track time
kcadby
posted January 21, 2006 08:06 PM        Edited By: kcadby on 21 Jan 2006 20:10
YEEEup...
I'm with jc...
Heat cycles...more than miles...
Actual DragBikes I built/build...get started and heated up a couple of times, taken to the track for a couple of "easy runs" down the track, take bike home/shop and re-torq the head after cool down (old-school copper head gasket motors).
Then...SPANK IT!!!
We put heat cycles on John's 1260 (some on dyno while LowSpeed mapping) plus a hundred or so miles on it before I did the WFO mapping...
Then he RACED IT...all year last year...
More than one ZX12 has been 124+ with Stock Motor
0.23170208930969 seconds processing time
