BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: n20 install this weekend,some questions NEW TOPIC NEW POLL POST REPLY
chevelle
posted November 17, 2005 12:39 AM
i have my dyno tune dry kit,and ready to install this weekend,but have a few questions,
should i go direct to the battery with a inline fuse,or is there a easy 12 v switched source ?
is anyone installing the nozzles (elbows in my case) in the snorkels,or should i go to the airbox ?
i have read over and over in my search that no fuel enrichment is needed for a small shot,(this scares me)i will start with a .028 jet at the solinoid,i made up a map with +5's from 7 k up,n20 will start at 8 k
also thinking about pulling out a degree or 2 from 7500
any problem using my muzzy co2 shifter with the juice ?
any help appreciated
johnnycheese
posted November 17, 2005 05:27 AM
put the nozzle in the center not in one side or your spray won't be even and could melt #1 or #4
zxmoose
in search of next kill
posted November 18, 2005 05:26 AM
pm sent!
posted November 18, 2005 07:53 AM
Suppose he has "2" nozzles?? (Dry Set up)
zxmoose
posted November 18, 2005 08:13 AM
i do mounted in front of the filters! works great....
posted November 18, 2005 10:14 AM
See, That is what I am talking about!
johnnycheese
posted November 18, 2005 01:59 PM
ditto here
chevelle
posted November 18, 2005 03:40 PM
thanks all,the airbox it is
turbo1320
posted November 18, 2005 08:06 PM        Edited By: turbo1320 on 18 Nov 2005 20:08
It wont shift with a big load but you could use a relay wired to the NOS solenoid to kill when you shift also mount the air shifter solenoid on the ram then you can shorten up the kill time.www.1320straightliners.com
chevelle
posted November 19, 2005 03:00 AM
thanks turbo 1320,no plans for a big shot on the 12,.028 jet or smaller is my current thinking,just looking for a little something,may even put the stock (modded)exhaust back on it,because it works so well from idle to 3k,but it does weigh a ton and hurts power above 7 k,just not sure what i am going to do right now,btw i rarely go to the track anymore,never ran the 12 and only ran the busa a few times (before the juice,9.87 @ 142) the bikes are street ridden only,no time or real desire to race anymore,here is a pic of the setup on the busa
johnnycheese
posted November 19, 2005 05:31 AM
WHAT????
I have some spraying 100-120-135- 150 shots and no problem shifting.
trust me the less wires and relays the better.
Red1
posted November 19, 2005 06:28 AM
JC,
You still doing any work on bikes? Just wondering....because I'm in the Dallas metroplex and have a NOS install coming and if your still doing work I may bring my bike to you! By the way....it's a 12!
Thanks,
Red
Red12/Blue14
johnnycheese
posted November 19, 2005 06:38 AM
I am kinda just taking in one at a time this way I can be with my Family.
email or pm me when you get close.
johnnycheese_2000@yahoo.com
Red1
posted November 19, 2005 11:15 AM
Thanks JC,
Glad to hear you are still hanging in there!!
Red12/Blue14
chevelle
posted November 20, 2005 11:23 PM
it seems as if the digi kill "gave up" yesterday,should i just replace it,or go with a ignition kill box for the n2o,this shifter has worked flawlessly for the past 18 monts
0.22097206115723 seconds processing time
