BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: EFIR question NEW TOPIC NEW POLL POST REPLY
canadamaxxer
posted August 07, 2005 06:07 PM
EFIR question
I just got my EFIR installed today, and I am wondering if I should be matching the timing retard rate to the time to 100% nitrous on the progressive controller, or if there is some other logic......
any help is appreciated...
RAC4IT
Bergie
posted August 08, 2005 03:21 AM
Doesn't matter. The box pulls 1.5 degrees just be connected to the bike, remember that when you program it.
canadamaxxer
posted August 08, 2005 04:24 AM
yeah I did see that statement...but they worded it as "removing 1.5 degrees at 10,000 rpm". I have assumed that this meant that it was a "ramp" effect, where it eventually got to 1.5 degrees. Either way....I have a pc3r so I can tune accordingly.
So.....if I'm reading you correctly....the time to full retard (dip switches 5-8) is not an appreciable factor ? I had thought that if I had my progressive box set at 2.5 seconds (as an example) to 100% pulse width on the solenoids, that it would be wise to try to match that rate in the EFIR. If this is not neccesary to do, this will be a good thing....as it's one less thing to have to monkey with...
0.21349191665649 seconds processing time
