BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: StremX Floating Rotor NEW TOPIC NEW POLL POST REPLY
Megabyte
posted June 01, 2005 10:34 AM
Anybody tried these Wave Rotors? They are less than $250 for a pair.
Fits Years:2000-2003
Braking Wave Rotors - Kawasaki ZX12R
Braking's most common floating rotors feature aluminum hubs. These are efficient, economical and normally replace similar brakes on today's modern sportbikes. Braking guarantees great quality while also improving the look of your motorcycle. Each aluminum floating hub is neatly anodized gray and the brake disk surface is finished according to ISO standards and all non- finished surfaces are powder coated to prevent oxidation. Depending on the application, the rotor may be attached via riveted buttons or Riveted plates
StremX Floating Rotor with Carbon Fiber Carrier & Riveted Plates
After many long-term tests, BRAKING set up floating rotors with carbon fiber carriers for use on sportbikes and motocross bikes. These carriers are built using special carbon fiber technology. Alternating layers of fibers are impregnated with resins which retain their original characteristics at high temperatures. The strength, appearance and weight savings are some of the best aspects of a carbon fiber carrier. Rotors mounted on carbon fiber carriers have more lateral strength than standard floating rotors and can weigh less.
0.2844409942627 seconds processing time
