BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: 6-gear gearing? NEW TOPIC NEW POLL POST REPLY
Farmer Rog
posted January 26, 2005 09:39 AM
6-gear gearing?
What gearing will use all 6 at 165-170mph?
ZX-12R, stock motor, Muzzy/PC3 63in, 60-shot dry, 750#, 9.001
ZX-14, stock motor, Brock smeg/PC3, 63.5in, ~750#, 9.31 NA, 8.95 40-shot dry.
NorthwestDragbike.com
osti33
posted January 26, 2005 02:56 PM        Edited By: osti33 on 26 Jan 2005 14:57
17-51 put me through at 161mph in 6th gear on nitrous. Probably had room to get to 165 but not 170.
Maybe 17-49 or 17-48.
zrxdean
posted January 26, 2005 08:00 PM
There's a freeware gearing calculator that is perfect for this. With wheel diameter, crank & clutch teeth, each gear ratio & sprocket size, you can calculate each gear's top speed at a given redline.
Dean
http://www.winsite.com/bin/Info?500000019820
zx12richard
The Green Monster..
posted January 26, 2005 09:15 PM
Whats the clutch and crank tooth number on a stock 12 crank and a falicon basket?????/
matt sterbator
Hiding in the bushes
posted January 26, 2005 09:50 PM
Falicon basket uses the stock gear.
your car is slow
Fuck Nitrous...Got Boost?
posted January 26, 2005 10:31 PM
17/48 topped out around 174ish on GPS when I had that gearing.
Do not taunt happy fun ball!
zx12richard
The Green Monster..
posted January 26, 2005 10:48 PM
Its already on the bike and I didn't count the teeth 2 years ago when I put it on...LOL
Thats why I wonder those 2 varibles.... Have the others....
But without those 2 calculator wont be any good will it???
matt sterbator
posted January 26, 2005 11:06 PM
I can't get to the calculator from here at work, but shouldn't it be the final drive ratio they're asking for ?
zrxdean
posted January 27, 2005 09:22 AM
The calculator needs all the gear ratios from crank to drive sprocket, it has no OEM data from specific bikes. I think you can get it from the OEM parts diagrams.
0.23118901252747 seconds processing time
