BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: freshening up the engine NEW TOPIC NEW POLL POST REPLY
aliveagain
posted November 09, 2004 08:17 AM
I've read where members were having their motors freshened up.At what criteria or how many runs do you use as a guide line?Or is it,if the et drops .10 seconds then its time?I guess it could be good info to anyone considering buying a used bike,any info?thanx
psycho1122
posted November 09, 2004 08:39 AM
Monitor the engines compression and oil pressure. The service book gives you a range the oil pressure should be at.
I would compare your compression to earlier #'s AND make sure all cylinders are within 5% of each other.
Keep everything properly adjusted (Valves, Cam Chain, Clutch)and KEEP YOUR OILING SYSTEM SERVICED (screen, rotor).....If all this is done, a "freshen up" may not be nessessary.
wannabe
posted November 09, 2004 08:23 PM
what exactly is included in 'freshening up' a motor?
posted November 09, 2004 10:06 PM
my motor gets "freshened up" when it stops turning. usually involves pistons, rings, bearings, valves, rods, crank, cases, timing chain, oil pick up, etc. but shit, i break everything i touch
ZXLNT
posted November 09, 2004 10:25 PM
LOL....
posted November 10, 2004 05:37 AM
mine almost always involves bearings...
Karl, LMAO... you da man!
osti33
posted November 10, 2004 07:17 AM
LMAO!!
johnnycheese
posted November 10, 2004 07:21 AM
and it hurts when I laugh so stop that
posted November 10, 2004 09:14 AM
oh yeah, and i forgot the head, cyl block, and cams; they've had to be "freshened up" from time to time.
aliveagain
posted November 10, 2004 06:58 PM
cheap bastard hasn't been replacing the cylinder studs,they must be chrome!
Johnnycheese
posted November 10, 2004 08:46 PM
That is because they are bolts not studs
posted November 10, 2004 08:50 PM
wow mine are studs with nuts.
psycho1122
posted November 11, 2004 08:14 AM
LOL...LOL!!
aliveagain
posted November 12, 2004 01:44 PM
duh!Now thats just like me,I can never get the punch line right.Sharp eye though Johnnycheese.I guess thats an attribute to your being a noted builder,attention to details.
0.23776507377625 seconds processing time
