BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Clutches NEW TOPIC NEW POLL POST REPLY
rquinn
posted September 07, 2004 03:01 PM
Clutches
Is there any one out there that can help me I am having a serious problem with my clutches. I cannot go to track and finsh a race without them going out in about 3 passes. The bike is 2001 ZX12R in opening I noticeds that the plates were very dry. I dont understand why cause I have the oil peice that Muzzy makes. Also I have a Billet Basket. At one point in time I had a MTC Multi Stage Lockup and there was still a problem present. So right now I am about out of ideas. I've had the mind to drop the oil pan to check the screen to make sure that it is clean to see if that the problem. If there is any suggestion please all of your help in this matter will be appreciated.
RON QUINN
zrxdean
posted September 07, 2004 03:10 PM
Your pickup screen won't affect your clutch, but it's a real good idea to make sure it's clean. If you've gone through a bunch of plates I would check it NOW.
I'd make sure your stack height (the total "width" of all your steel and fiber clutch plates) is correct.
your car is slow
Fuck Nitrous...Got Boost?
posted September 07, 2004 03:25 PM
Some people get a lil squirter bottle full of oil to spray on the plates before you go run. Others tip the bike over to the right as far as possible (try not to drop it) and work the clutch with it out of gear to get more coverage on the plates.
Mainly the best advice is to make sure you allow for proper cooldown between each run (20 to 30min...use a fan to expedite the process if you have to).
However if you really slip the clutch agressively off the line...nothing will keep the plates alive for the long haul....can only put off the inevitable
Do not taunt happy fun ball!
aliveagain
posted September 07, 2004 03:29 PM
The oil level is correct,right?
posted September 07, 2004 04:05 PM
what gearing do you have, whats your wheelbase, what RPM do you launch at, what oil do you use, how many friction plates, how many steels-what size, what clutch springs, Muzzy Hub or OEM???
RDQUINN
posted September 07, 2004 07:27 PM
My gearing is 17/46 I'm realatively kind of aggressive leaving at around 5 to 6 grand. I'm about 210 with leathers on the last set that I just recently put in were spank brand new probadly set in the bike about 2 weeks. Before I showed up at the track with it. The thing that I think that I will have to do is the day before I go to the track is to take them out and soak them in oil all over again. As far as the oil that I used it was the Mobil 4xt F/S the first time I've tried because everybody talks about how good it works. However; I was having problems before then as far as the clutches I have had some of them all stock & the muzzys.
your car is slow
posted September 07, 2004 07:44 PM
2.0mm steels or the stock 1.6s? (if the 1.6s..ditch them for the 2.0s)
wannabe
posted September 07, 2004 08:27 PM
Am I the only one here who thinks that too much oil in the clutch pack is bad? The last time I tried launching with freshly oiled clutch fibers in my bike, the bike pulled me into a red light right when I got onto my 2-step. Too much oil = too much drag.
ZX12Girl
Adrenaline Junkie
posted September 08, 2004 02:54 PM
Welcome to the dragracing world of the clutch eating ZX12R!!!!
I try to use the following rules -
(Clutch mod (recall) / 2.0 steels)
1. Allow 20-30 minutes between each pass
2. Soak the clutches in oil before initial assembly (Kzz1 takes care of that) but not every time we go racing.
3. Lean the bike and work the clutch lever before burn out. (I am a lightweight so this probably does no good for me - not leaning enough)
4. Leave at a lower RPM and let the clutch go.
Even with this, the clutches last about 2 trips to the track.
Marcos Peguero
posted October 09, 2004 06:44 AM
Anyone have tried hyperplates?
  Ignore this member    Click here to visit Marcos Peguero's homepage.
ninja12
posted October 09, 2004 07:28 AM        Edited By: ninja12 on 9 Oct 2004 08:28
The oil squirter will not work with a billet basket.
You should not be racing without the billet basket.
Do you still have the multi stage, want to sell it?
Send me a PM.
your car is slow
posted October 09, 2004 08:53 AM
some people drill holes in the outside of the basket.
but you can indeed still use the squirter bottle...it will get into the basket from the edge.
posted October 09, 2004 01:27 PM
you are not the only one
when i install a new clutch, I always just dunk em, install em, then run them. The clutch is always pulling when it is brand new but settles down quickly with just a run around the block.
ninja12
posted October 09, 2004 05:06 PM
ycis, i don't trust mods to the basket.
areou said that you can squirt oil on the 1-2 outer fiber
it will actually help?
your car is slow
posted October 09, 2004 05:45 PM
well it IS oil....its not going to just sit there in the spot you squirt it
01zx12r
posted October 10, 2004 03:43 PM
The only fix I have found is to pull the clutch every pass with a lock-up style clutch. Lighter the rider the easier on the clutch. Another option that has helped is Valvoline 20w50 racing oil.
Lovett Racing/Pedigo Performance
8.40 @170
01zx12r
posted October 10, 2004 03:46 PM
Another thing, how long are you soaking your fibers before installation?
8.40 @170
posted October 10, 2004 05:08 PM
wannabe, just oil soaked clutches or did you have fresh clutches too???
I have tried soaking the entire clutch in oil and the clutch was great for 2 passes, smooth and no squeeling...Then it started the squeeling again!!!
YCIS...I have to try putting oil in a spray bottle and spray it into the oil filler hole...
wannabe
posted October 10, 2004 05:19 PM
CR, it did it with both. I took the clutch apart at the track one day and figured that I would resoak the fibers before I put them back in. The clutch pulled me into a red light the next pass. Too much oil = extra drag from the clutch.
wezze93
posted October 10, 2004 09:11 PM
im having problems with my clutch an mtc single stage lock-up i tried to run three weights an washer it ran good mph on the spray but my 60ft. is not good, because it lock up to soon. so i took all the weight off i could come out better an my mph was good on motor but when i sprayed it my clutchs start slipping what can i do to get it to leave good an hold up the spray
  Ignore this member    Click here to send wezze93 an AIM message.
wezze93
posted October 10, 2004 10:25 PM
it a two stage lock-up
psycho1122
posted October 12, 2004 07:48 AM
Easy mod to Solve problem!
Have the Puller Shaft Cross Drilled .040!!
This will allow for a "Dual Spray" of oil inside the Hub during operation.
The 05 ZX12 has this mod on the Puller Shaft. (FINALLY!!)
DR JOE
posted October 12, 2004 08:56 AM        Edited By: DR JOE on 12 Oct 2004 10:01
You are part right psyco1122...
You have to grind a small spot on the shaft @ 1.65 from the hole end (inside) and drill a .#40 hole (Use only a .#40 and no bigger and it's to much oil, read below). Also if you are using a stock inner hub it needs to be drilled also. Same drill bit and make 6 equal marks around the hub with a sharpie mark the 6 spots. Now take the hub and measure from the inside 3/8 an inch and mark it, do the same for the outside. Now split the difference and mark in the middle. you should now have 18 holes marked. Drill and clean very well, all the time your doing this soak your clutches and steel. Reassemble making sure that your cluch pack is in tolerance. test bike, enjoy the ride.
This works I have done it on 2 bikes with no ill effects and very streetable, you can't tell the difference that it has been done, but your clutches know.
Also my bike has so much oil going to it that it does pull on me at the light @ 8000 and yes I have to hold it back. But I have had the same clutches in there for 2 years now and they still look like they did 2 years ago.
01ZX12r has seen this bike go.
DR JOE
Marcos Peguero
posted October 12, 2004 11:51 AM
Im chaging the 2000 hub for a 2003 hub with springs, since I have a new set of frictions.
To prevent from problems.
Even with the 2003 hub do I have to drill the hub?
psycho1122
posted October 12, 2004 03:24 PM        Edited By: psycho1122 on 12 Oct 2004 16:25
Dr. Joe
My mod has worked properly for over 4 years w/o a single blue'd drive plate.
NO "Flat Spot" grinding needed.
I also assumed that people already have the Hub drilled. I use the Muzzy's clutch kit along w/ my mod.
My Pusher was drilled using EDM and the hole is located just inside of the needle bearing landing for the Pressure Plate.
Oh and it's spelled...psycHo!
0.26422190666199 seconds processing time
