01ZX12R
posted August 09, 2004 04:07 PM
chassis set up
Im having so many problems with the chassis/clutch set up with my 12. Most I believe are shock problems. Without making a post very long will somebody email me and try to help me with the set up? The bike has been 8.89 at 166 and makes over 300hp. Thanks in advance. Chris azx12rush@aol.com
Im to a point if I need to take the bike somewhere, fly someone to me, pay out the a$$ im ready.
Lovett Racing/Pedigo Performance
8.40 @170
your car is slow
Fuck Nitrous...Got Boost?
posted August 09, 2004 04:19 PM
2 questions that would probably facilitate better answers.
1. Where are you located
2. What rear shock are you using?
Do not taunt happy fun ball!
posted August 09, 2004 06:18 PM
http://www.gmdcomputrack.com/
posted August 09, 2004 06:21 PM
Ok I just freaking posted! damn thing. anyway where are you located? and how are you launching? what problems are you having? do you have any video you can send me?
thanks.
Mad Mike
01ZX12R
posted August 09, 2004 09:29 PM
Hey guys, sorry just didnt want to make a long post.
Bike...68in.
MTC lockup
1320 with N2O
leaving at 7500 dumping clutch and pinning throttle
2.5 inches ground clearance
WORKS shock (think its to long) causing suspension to bottom out.
Shootout tire...10-13psi
230lbs with gear
17-48th
I do have video but would like to convert it so i could send to people on the net...any help there?
Location....Wichita Ks
8.40 @170
posted August 10, 2004 05:34 AM
I can come to the PMRA Race this sunday if you would like? let me know I am trying to get a friend of mine to go with and split the fuel....
posted August 10, 2004 09:01 AM
01zx12r
how about posting the times/mph of a typical pass for you.
I am about 220# w/gear; 68", MTC 2 stage, 1427 all motor, with a Penske shock. I'm not leaving as hard as you but my shock sure doesn't bottom out. My stock shock/spring had problems with my TFA even with a 6" arm.
01ZX12R
posted August 10, 2004 03:02 PM
Entropy, who did you get your shock from and who set it up? I should have my works shock back for this weekends PMRA race. I think we found some length problems.
8.40 @170
posted August 11, 2004 11:30 PM
I got it from Orient, they asked about arm length, hp, my weight, then "designed" the spring/shock accordingly. I can't seem to find the specs but I believe my Penske is 1" shorter than stock, has different valving, and a heavier spring. About a grand. I may be "dis-remembering" some of this.
BUT, it's a world of difference.
RAC4IT
Bergie
posted August 12, 2004 03:33 AM
send me the video i can convert it for you
zx12richard
The Green Monster..
posted August 13, 2004 09:25 PM
quote: http://www.gmdcomputrack.com/
Very much agreed... See Scott GMD in Manfield TX...
682-518-1660
01ZX12R
posted August 17, 2004 03:54 PM
New best
I had a pretty good weekend. Hats off to Peire? at Works Suspension and their awsome work.
The bike now leaves pretty good compaired to the past. best 60ft was a 1.56 and ran an 8.83 at 166mph. The bike carries the wheel about an inch off the ground to the 60ft clock but then starts to wheelie to where I have to chop the throttle. I think ive found the problem in that area. A little more clutch management should fix the problem.
Im also planning on making some weights to hang off the front of the bike somewhere..Anyone have any ideas?
Once again I have alot of video but all on vhs. I will have to get them sent out to be converted.
8.40 @170
1bad12r
posted August 17, 2004 04:38 PM
Good luck on getting any help with the weights. Its like a matter of national security or somthing.
768 Ryderz
01ZX12R
posted August 17, 2004 05:58 PM
I dont think thats really the truth. Its different from bike to bike, rider to rider. But here is one piece of advise...If you have tire spin, or you have to back out of the power during a pass while the bike is moving, the clutch locks up. That seems to be my problem right now is tire spin causing lockup of the clutch. Another thing to keep in mind this clutch is overkill. So far ive got the clutch set at minimum and its still to much. From what ive learned we as 12 owners need very little in the lock-up end of the clutch.
8.40 @170
