BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: 1/8 mile stock 12 NEW TOPIC NEW POLL POST REPLY
ddpete3
posted January 21, 2002 11:20 PM
1/8 mile stock 12
In San Diego, they have this legal street racing thing going on sponsored by the cops. 1/8 of a mile.
What do you think a stock 12 will run that in?
250lb person on board.
  Ignore this member    Click here to visit ddpete3's homepage.
kcadby
posted January 22, 2002 01:47 AM
Low 7s...maybe high 6s @ 100-110mph...
brickman
posted January 22, 2002 05:51 PM
660 at113
kcadby
posted January 22, 2002 09:18 PM
660 at113
My numbers are for a stock bike (not lowered or strapped) with a 250lb rider on the STREET...
My first time to the TRACK on a TOTALY stock, not lowered 12, I ran 6.78 @ 112.86...that's at 165lbs...
With Ti-pipe, bike lowered (not strapped) and 17-tooth front, 6.60s @ 114mph...
After 15 runs of practice, timing advance and motor breaking in more...6.47 @ 117mph...still at 165lb...
ddpete3
posted January 22, 2002 11:44 PM
It'll be my first time running any kind of track race.
I figure I do it from green lights all the time...what could be the dif, huh?
So, give me some pointers on how you start and when you shift.
kcadby
posted January 23, 2002 12:17 PM
Do it the same as you do it from a lite...
Lean as far forward as possible...shift into 2nd when the wheel starts coming up in 1st...if your lucky???and it doesn't come up in 1st???(doubtful)...then shift at AT LEAST 11,500 on your tach...the tachs read high...
If you have stock gearing...2nd will get you to the 1/8...
One tooth down on the front will get you there in 3rd...
Good luck and HAVE FUN...
ddpete3
posted January 23, 2002 05:41 PM
Do You rev the bike at all befoe dumping the clutch?
slowly let out the clutch?
kcadby
posted January 24, 2002 03:57 AM
Rev it to between 3 and 4-thousand to start out...be as smooth as you can SLIPPING the clutch out...trying to keep the revs steady with clutch/throttle as you "drive off"...
Once you feel comfy doing this...raise the "launch" rpm a little at a time until you reach the point where you wheelie OR spin the tire (if traction sucks)...then???
BACK OFF A LITTLE...
ddpete3
posted February 16, 2002 01:37 AM        Edited By: ddpete3 on 16 Feb 2002 01:40
Went tonight.
Won first place in the heads up division.
Here's my winning ticket thing.
And stock, I had to shift into thrid or I redlined across the line.
I'm addicted
kcadby
posted February 18, 2002 04:11 AM
COOOL...
You'll go quicker and faster ever time you go out when 1st starting out...
Who cares how fast/slow if your WINNING though...huh?!?!?!
0.21607518196106 seconds processing time
