BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: gsxr 1000 oil light NEW TOPIC NEW POLL POST REPLY
draggsxr750
posted May 28, 2004 06:55 AM
gsxr 1000 oil light
first time out at track kept getting oil light when i bogged the motor below idle just letting oil in my clutches is this common or do i have a prob motor was bought at scrap yard used out of wreaked bike never opened to air has 3000 miles on it also drained oil and found four small pieces like slivers of metal this is normal or a huge prob. im using amsoil oil and oil presure at idle is about 8 to 10 psi and at 3000 rpm its about 20 or so very close i also took oil pressure on my buddies 750 brand new had same reading any idea or am i blowing this out of proportion thanks guys and gals
posted May 28, 2004 07:22 AM
if you oil light is coming on it is a Big Problem. but depending on what the problem is depends on how bad. main item would be are the pressure sensors the same for both motor's? or does you ecu read them differently? and where on the oil level are you running the motor?
that info will help.
draggsxr750
posted May 28, 2004 08:30 AM
as far as the pressure sensor go i have no idea i checked the oil pressure with a manual guage on both motors got the exact same reading so i dont think i have a pressure prob contacted lee performance they say oil pressure is fine i think the oil got so hot that it was coming on due to low oil presssure when i let motor go below idle. the light came on like way below idle i was testing where the clutch let out at idle the switch is set to go off at 2psi motor only runs at 7psi at idle i think i just got it down so low that the light came on . on the way home as motor cooled to normal operating temp the problem went away less than three miles from the strip im going by coolant temps ran about 228 at the track and 178 on the highway so not sure what the deal here is the reason im so skitz just lost my other motor about three weeks ago only ran this motor about 400 miles on street only oil level was set to factory spec in sight glass
BA
posted May 28, 2004 10:58 AM
i may be making LESS of this than I should but I'm not as concerned as Mike is yet.
I've gotten an oil light once or twice (out of 50 times) while tipping the bike to the right and getting oil on the clutches. I was doing it for too long at a time. Is this what you are doing?
I wasn't too sure what this meant: "i bogged the motor below idle just letting oil in my clutches "
of course, on my situation, I would tip the bike upright instantly, but since you are referring to a near idle condition, and trying to get oil on the clutches I figured you were doing something similar.
Now, if you're just idling and BAM, low oil pressure. I'd be a bit concerned!
draggsxr750
posted May 28, 2004 11:53 AM
yes ba that was exactly what i was doing but
after i seen it i made the pass came back to pits and tried it again nothing happened but by accident i just slipped the clutch at idle as clutch grapped the rpm went below idle and the light came on like below 1000 rpm this was with bike up right the guys at lee's say this is comon with a 1000 so i dont know glad to see im not the only one on tha boat thanks ba what kinda of oil do u use
BA
posted May 28, 2004 02:43 PM
I can't seem to make up my mind between Motorex oil and Mobil-1.
I've tried Royal Purple on other bikes and didn't notice any trouble.
I 'need' to seek out some Motul......
draggsxr750
posted May 28, 2004 04:28 PM
yea i just went with mobil 1 bike wont do it again so maybe what we were talking about is tha prob thanks for your help man u made me feeel hell of lot better
0.28871512413025 seconds processing time
