BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Front Brake Problem NEW TOPIC NEW POLL POST REPLY
magzx12r
posted December 02, 2003 10:15 AM
Front Brake Problem
I am still having a problem with the amount of "free travel" of the front brake lever. It is as if the pistons in the front caliper are pulling back too much after I release the brake lever.
I put in new pads a while back and that decreased the "free travel" of the lever a great deal. However, as the pads wear and become thinner, the excess "free travel" in the brake lever comes back. One thing I noticed when checking out the calipers is that the outside pad on both calipers does not sit tight in the caliper against the disk after I apply and release the brake lever a few times. The inside pad on both calipers sits tight against the rotor.
I do NOT think this is a rotor issue because this happens when the bike is sitting still in my garage without the front wheel moving. Also, I don't get any vibration when I am riding and use the front brakes.
I have Goodridge kevlar lines, EBC race lite rotors, EBC HH brake pads, Motul Fluid. Also, I have bled the lines several times to remove air. I also tried the Zip tie trick with the lever overnight, but it only temporarily firms the lever up. Any suggestions?
Mark
'03 ZX-12R
'12 1199S
ScaredyCat
posted December 02, 2003 10:39 AM
Mark,
I had the same thing. There is at least one fairly long post on the subject, but try checking your caliper piston dust seals, make sure they're not swollen and/or sticking to the pistons. That fixed it for me (oh yeah, a bit of coppergrease around the piston keeps them OK for longer).
If the tie-wrap trick works for a while, I'd bet money on a sticky caliper piston (I've stripped kawa brakes soooo many times for this reason, but then I was riding in UK wintertime, salted roads etc).
If it ain't broke, BREAK IT.
  Ignore this member    Click here to send ScaredyCat an ICQ message. Click here to add 313822511 to your ICQ list.
magzx12r
posted December 02, 2003 04:16 PM
Front Brake Problems
I will check on the dust seals and try the copper grease. I had the calipers "rebuilt" a while back and it seems that the problem is worse now than before the rebuild.
Mark
'03 ZX-12R
'12 1199S
0.69663095474243 seconds processing time
