BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Muzzy fork strap NEW TOPIC NEW POLL POST REPLY
aliveagain
posted November 13, 2003 06:25 PM
Muzzy fork strap
Just trying to do it right the first time.Which end of the strap would you put on the lower caliper bolt and any helpful hints on what to do with the free end?
posted November 13, 2003 07:30 PM
Doesn't the free end go around your neck?
aliveagain
posted November 14, 2003 09:23 AM
you mean thats what everyone has been attaching to their sleeve?COOL!
tccycles84
posted November 14, 2003 10:19 AM
why strap just lower it on the tubes that is goodand a Muzzy link kit for the back and you will be on the ground all that is needed
zxlnt
posted November 14, 2003 02:06 PM
Strap is easier and a little more temporary job that raising the forks up each time you want to go drag race.. Plus it gives a little bit of steering damping action as you tighten the strap..
matt sterbator
Hiding in the bushes
posted November 14, 2003 03:18 PM
I don't lower my fork tubes because I like it full height when I ride it on the street. What little twisties I have to ride I want to enjoy
So it gets strapped when I go to the track.
aliveagain
posted November 14, 2003 07:40 PM
I have to find some spacers tomorrow for the caliper bolts.Thinking about sewing velcro on to the loop end so it won't dangle and will be readily in reach.
harryzx-12
posted November 15, 2003 04:55 AM
two lock washers work perfect as a spacer and you need to zip tie that strap or you will have problems. you dont want the pull end coming loose and getting in your front wheel...
Mad Mike
aliveagain
posted November 15, 2003 02:52 PM
thanx MM,I have to wait until I get the shorter bolts to eliminate the reflectors.m6-40mm I believe someone said
0.24233102798462 seconds processing time
