posted November 03, 2003 03:57 AM
Edited By: entropy on 3 Nov 2003 04:04
teardown: headgasket blown at Texas Mile
JohnnyCheese did comp and leakdown tests, then took off the head & block to see why I was getting bubbles in the overflow after running the Texas Mile.
yep, just as suspected, the headgasket was leaking between 1-2, 3-4 (2-3?) and obviously some compression was getting into the coolant .
Question is why?
A good suspect is that motor was running very lean at extended WOT and detonation set in; piston tops had that "mini-sandblasted" look which the experts say = detonation, and the tailpipe had a rusted look (too lean??), rather than Nutec gray.
Motor was dyno tuned for 12.8-13.0 and ran great at 1/4mi, but perhaps extended WOT leaned it out???
Now to check head & block for flat, then decide what headgasket to run (copper or 3 pc coated ss), and whether to O ring it or not.
To be continued...
posted November 03, 2003 04:15 AM
What kind of pipe are you running?
posted November 03, 2003 05:48 AM
Brock's Hindle
catman12
posted November 03, 2003 06:34 AM
Do you have stock fuelpump??
6.23@126.7mph 1/8mi , 9.44@150.99mph 1/4mi 60" Arm, 1361cc, manual shifting.
http://www.kiruna.se/~mgrape
posted November 03, 2003 08:03 AM
quote: Do you have stock fuelpump??
Muzzy pump.
addisonzx12
posted November 03, 2003 09:16 AM
Being the head gasket blew out, that would make the bike run lean also. Sucking air!! Don't know how you could tell if it was lean BEFORE the gasket blew though. Just a thought to consider. JC has probably seen a lot of this on all those busas he tunes.
posted November 03, 2003 11:56 AM
Well good luck with the re-build Karl!! hope it all fixes it.
Mad Mike
posted November 03, 2003 12:04 PM
As usual, D Meyer to the rescue; running lean/detonation is bad; new 3pc steel headgasket is good
addison,
i don't know about the gasket blowing THEN getting a lean situation???
But then again, I am a "hamma-mechanic"
posted November 03, 2003 07:29 PM
I don't think it could suck air, seeing that you were getting bubbles in the coolant...
posted November 04, 2003 07:33 AM
A head gasket failure like Entropy experienced is almost always caused by detonation, most likey a result of a lean mix or too much ignition lead.
On a larger bore engine, the narrow area between the cylinders is most suseptible to the heat and high cylinder pressures that result from detonation.
Doug
rac4it
Bergie
posted November 04, 2003 08:11 AM
what do you suggest to prevent this in the future?
posted November 04, 2003 09:41 AM
Edited By: entropy on 4 Nov 2003 09:45
I am SURE Doug has lots o' remedies; prolly none of which include going slower!
What the Cheeseman will do is:
1. make sure head, block, pistons, valves are all in tip-top condition or put em that way.
2. use a 3 pc steel head gasket; NOT O-ring block or head.
3. cc the head and determine the real CR so that I use the right spec racing fuel. We will use base gaskets to get the CR to about 13 to 13.5:1 (unless someone has a better idea)
4. make a 2nd map just for top end which has a bit less advance and a bit more fuel.
BTW: Once again, Doug Meyer's rapid, thorough advice has reaffirmed one of the reasons why I am a VERY loyal customer of Muzzys. Doug responded to me in detail, several exchanges, patiently explaining issues associated with my current situation.
You DA MAN, Doug!!
addisonzx12
posted November 04, 2003 09:56 AM
How much advance did you have in the map?
posted November 04, 2003 10:40 AM
5 at WOT.
A couple mo ago we tried more and tried less on the dyno, but 5 was the magic number.
posted November 05, 2003 06:14 AM
That don't seem too bad. Wonder how your fuel mixture was?
posted November 05, 2003 03:05 PM
12.8 - 13
RAC4IT
Bergie
posted November 05, 2003 04:26 PM
For future reference, I was pulling higher traps N/A at Maxton with timing retarded not advanced.
posted November 05, 2003 04:39 PM
More torque, maybe?
posted November 05, 2003 06:05 PM
more torque = more hp
Bergie, you figure that taking timing out does something good with increased air pressure thru the snout???
posted November 05, 2003 07:00 PM
Same thing with the guys in South FL. THey all run less timing than stock for the best mph.
ZXALAN
posted November 05, 2003 07:02 PM
My bike made more power in the dyno with less timing in the tables on the PCII. Going from "5" down to "2" gained 3 hp across the band. NOTE this is in a pcii, not using a mechanical advancer. WE don't have those on busas.
You always need less timing advance/lead at high rpms. On the cars, we used to use a timing retard module that would reduce advance degrees per every thousand rpms. On the cars we would start out at 36-38 degrees total timing a WOT and by the 6000 redline we would be down to 32 or so. We could also control it by gear position. top of 3rd (hi) would would pull out atleast 4 degrees just because of the extreme load on the motor in high gear, this is not even talking about when the dope was sprayin. All of this is dynamic to burn rate also. AKA How high is your octane?? DEMZ Old school cars wuz fun back in da day.
Dyna ignitions rule for carbed bikes, I can't wait until Schnitz gets em working right for busas and 12s. Karl, that might be sumthin for you! It would work well for top end shootouts!
posted November 06, 2003 12:08 AM
well, I have done several tests on the dyno and my bike always seems to make more hp at WOT with 5 adv....
BUT, on the mile things it may need to go less adv for hp AND to prevent detonation.
Alan,
when are you gonna have Johnny dip into the grocery getter???
posted November 06, 2003 06:10 AM
I always throught that you'd make more torque with less advance. After all, if you go waaaaaay back to when cars had manual advance, you would have to retard the advance before going up a hill to prevent detonation. Part of that was the crappy gas back then, but you get the idea...
rac4it
Bergie
posted November 06, 2003 08:53 AM
In this case, using positive advance we can determine that more horsepower on a dyno using advance doesn't necessarily mean you will go faster on the track.. Interesting huh? I ramp down my advance to finish with -2 degrees retard at the upper rpms on my LSR maps.
kcadby
posted November 06, 2003 09:56 AM
I don't run that much timming either...I decrease timming at the upper RPMs...
We have never run more than 4* on John's bike...I LIKE going FAST but not enough to push anything..."to the limit"... I HATE "hurting perfectly good parts" for the sake of a tiny bit more performance...
