BIKELAND > FORUMS > ZX12R ZONE.com > Thread: adjusting muzzy lowering links NEW TOPIC NEW POLL POST REPLY
Megabyte
posted October 07, 2003 12:13 PM        Edited By: Megabyte on 7 Oct 2003 13:14
Adjusting Muzzy Lowering Links
What is the best/quickest way to change holes on Muzzy's lowering links ? Second person, front stand, rear stand...?
Thanks,
wannabe
posted October 07, 2003 01:01 PM
Bike on rear stand. Jack under oil pan (with wood block in between jack and pan to keep from scratching the pan). No second person necessary.
tccycles84
posted October 21, 2003 12:18 PM
i hang my bike off of a engine hoist or from the roof of the shop with two tie down straps.
i allso put the bolt in the oppist way from factory ten min. max to reset hight. IN THE SHOP
your car is slow
Fuck Nitrous...Got Boost?
posted October 21, 2003 12:42 PM
bike on rear stand.....2x4 under passenger footpegs....supported by whatever (I use cinderblocks and jackstands)....remove rear stand...wheel shouldnt hit the ground.
remote bottom bolt (hope you put it in backwards)....move wheel up (I use a car tire ramp for this) to desired height...install bolt in bottom hole.
Do not taunt happy fun ball!
wannabe
posted October 21, 2003 12:47 PM
I still think that my way is much easier.
1bad12r
posted October 21, 2003 01:30 PM
Thanks Wannabe ! I always wondered if that would work.
768 Ryderz
Megabyte
posted October 21, 2003 01:32 PM
Thanks, I'll give wannabe's method a try and let you know....
wannabe
posted October 21, 2003 01:34 PM
By the way, depending on the type of rear stand you have, you may need to tie-wrap the stand to the bike so that it doesn't tip over. Just take it slow.
posted October 21, 2003 03:10 PM
Remove them and buy the threaded adjustables....lol. Problem solved!
wannabe
posted October 21, 2003 03:22 PM
Not solved completely. You still need to prop the bike up to remove them.
your car is slow
posted October 21, 2003 04:06 PM
why would you want to remove the threaded links?
wannabe
posted October 21, 2003 04:16 PM
I didn't mean remove the threaded links. I meant that you still have the same problem when you have to remove the stock dogbones to install the threaded links. Yeah, I know it's only a one-time thing, but if you don't know how to do it, it's still a problem.
zx12richard
The Green Monster..
posted October 21, 2003 05:45 PM
I just pivoted it up on the kickstand and had another person hold it... Raise or lower hanging onto the handle bars...... Thats how I adjust it... Only takes a couple seconds...
0.23290586471558 seconds processing time
