BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Q for electrical experts: Ground cable NEW TOPIC NEW POLL POST REPLY
posted September 07, 2003 12:58 PM
I have a bigger battery mounted in front of the swingarm and all works fine, but am replacing the 6 ga cables with audio grade 4ga. No problemo with + cable, but the goddamn - cable grounds onto the top of the trans under the battery box. Why did Kwak put it in a practically unreachable spot???
Is there something magical about that spot OR can I just ground it at a convenient spot on the motor??? Like the bolt on the upper left of the ign timing cover??
Thx for any help you can give
Dino
posted September 07, 2003 02:17 PM
It shouldn't make any difference as long as it's a GOOD ground, but I'm not an expert Where the hell did you put the battery???? I couldn't find room enough anywhere to put the rectifier!!!
uh oh
posted September 07, 2003 02:45 PM
Dino,
I have a 10" arm, lots o' room in front of the tire for a custom batt box.
BA
posted September 07, 2003 03:04 PM
If you find a good, clean spot on the engine, you will be fine.
Electrically (meaning 'the Ground') the tranny and the engine and probably even the frame are all the same.
Anytime they are not the same, you get the potential for a 'difference in ground' (electrically) and that leads to odd problems, especially if the owner has added cool stuff like a Screamer, O2 sensor, radar, etc. etc.
An engine ground is the same as the tranny ground, just do a good job on it.
posted September 07, 2003 03:49 PM
Thx BA!
As far as do a good job... I found Crutchfield, a co which supplies hi end car audio stuff. They have cables and ring connectors which will damn sure do the job. I had no idea car systems used such heavy ga electrical cables & connectors.
frEEk
posted September 07, 2003 04:21 PM
its just for when u get into serious amps. some put out well over 1000watts, and they're not exactly efficient, around 50% usually i think. so when u'r pumpin close to (or even over) 200 amps, u wanna big wire plus real big systems will use a whole bank of them big amps, so u prolyl get people running well in excess of 1000A to their amps. pretty insane stuff.
posted September 07, 2003 05:13 PM        Edited By: fish_antlers on 8 Sep 2003 08:15
anywhere should do.... a good idea may be to "bond" the Kawi ground to the actuall frame and then you could pick any point incase any bushings etc interfere or insulate the engine..
if you bonded the frame with a jumper then you could pick any point safely, be it on the frame or on the engine.
posted September 07, 2003 11:12 PM
frEEk, pretty insane stuff indeed, AND bling-bling colors as well!
fish: good idea!!!
zxlnt
posted September 08, 2003 02:16 AM
Karl don't waste the money ordering that stuff from Crutchfield. They are wayyyy overpriced. Check out a local pawn shop or something. Most of them have a car audio section and you can get everything you need there for a hell of lot less...
posted September 08, 2003 06:21 AM
Zxlnt,
NOW, you tell me... Hey, I am so impulsive, I can hardly wait for anything, already got my cable & connectors.
Yep, it is way overpriced, but that REAL FLEXIBLE 4ga cable in bling colors is pretty cool. $2.00/foot it outa be, eh?
kawachan
posted September 09, 2003 08:08 AM
Damn Karl....holler at em if you need some connectors. You know I used to be an installer....eh? Ran a store for five years before I moved to my current profession. Matter of fact, I did four installs last night (err...morning) for some of my friends. I've got quite a few short pieces of 4 ga laying around if you need some of that too......
Fish and BA are talking about "ground isolation" which causes lots of noises/problems in some 12v areas.
Some of the stereos we did before I left were in the 160db range (Outlaw) and lots of 00 cable and larger. Packs of batteries, capacitors, dual alternator setups.......shit got to be outrageous and EXPENSIVE quick!!
RED NINJAS RULE!!
posted September 09, 2003 08:33 AM
Chan,
Thanks for the offer, but I think I have all the pieces, now just get after it!!!
zxlnt
posted September 09, 2003 12:06 PM
Tellin me car stereo is expensive. I have 1400 watts in my car. Almost as expensive as damn cycles....
ScaredyCat
posted September 12, 2003 03:23 AM
I saw a documentary where all these sad fuckers had their cars rigged up like a Pink Floyd sound system, to the extent of REMOVING THE ENGINE.... All the participants were wearing earplugs. Errrrr. Hmmmm.
These guys would put their moolah to better use by paying for a few psych consultancy sessions, instead of that new 1,000,000 Watt amp that they can't hear because the last 500 Watt amp made them deaf.
At least a loud bike pipe sounds good - but friggin' "Cheeky Girls" at 200 dB? What's that all about then?
IMHO. No offence to all the fucking idiots that drive around with a "thumping bass".
If it ain't broke, BREAK IT.
  Ignore this member    Click here to send ScaredyCat an ICQ message. Click here to add 313822511 to your ICQ list.
EastBayDave
posted September 13, 2003 12:14 PM
I sure could use some. Man am I glad this subject came up as I just discovered I screwed up my neg. cable. Apparently I tightened the cover down on it, & it's squished right across the cable. The distance between "sides" now is about 1/8" where it was crushed.
What should I do?
a) Replace w/stocker? (~$15 from Ron Ayers)
b) Replace w/RF ground cable? (I got a bunch of it laying around from my ham radios [8ga. solid round copper wire]) ???
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
zxlnt
posted September 13, 2003 03:33 PM
Goto a pawn shop and get some flexible multistranded wire. Solid wire may break after a while due to vibration..
0.26703786849976 seconds processing time
