BIKELAND > FORUMS > ZX12R ZONE.com > Thread: adjusting power commander? NEW TOPIC NEW POLL POST REPLY
MarkZX12RKX500
posted August 20, 2003 08:24 PM        Edited By: MarkZX12RKX500 on 20 Aug 2003 21:46
Adjusting the power commander?
(((ok I am new to this power commander stuff))) it's lean all the way down should move it up how can I tell if and where I need to set it lean or rich???
Thankyou for any input.
OK I tried holding the 3 buttons down and turning the key and it won't move it stay's at lean all the way down muzzy down loaded a map on it for me is that why I don't know.
GOZR
GOZR
posted August 21, 2003 12:02 AM        Edited By: GOZR on 21 Aug 2003 01:02
I really think you should get to a dyno tune up because if you are using the lights and buttons you R note finish to pull out your hairs..
what is your setup on the bike? filters,pipe ?
-G
posted August 21, 2003 06:07 AM
uh... dont use the buttons... you need to get a hold of a laptop or yer computer and load the appropriate map into the unit.
FLY ZX12
posted August 21, 2003 06:08 AM
I am no expert but mine doesn't move from lean unless I rev up the engine. You might want to take it to a dyno tuner. I tuned mine by using a O2 sensor on a pipe put into the exhaust and a air/fuel gauge to monitor it at the different RPMs and throttle positions. I like doing stuff myself and it took about three weeks to get a map that was smooth and not too rich or lean. If you don't want to wait and done perfect a tuner is the way to go.
Hells Dark Lord
living life, and loving it.
posted August 21, 2003 06:48 AM
took my bike to kcadby in Jacksonville Fl...he mad a custom map for it at a reasonable price. Bike runs strong and smooth...its worth the money in my opinion.
GOZR
GOZR
posted August 21, 2003 08:05 AM        Edited By: GOZR on 21 Aug 2003 09:06
I did it my self took me a week of testing and mixing the best maps
I was doing one change and vrOOOOooooOOOOm down the road and back and do it again.
Than I'm really close to a great one i just need to get it better at 4000 to 1000 rpm sometime coughing on deceleration. BoOOFfff!
I'll remove the clean air plate mod real soon i think it's why.
than dynoed it..
-G
0.37993311882019 seconds processing time
