BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Carbon fiber maintenance (on exhaust canisters) NEW TOPIC NEW POLL POST REPLY
claude
posted August 12, 2003 04:06 AM
A friend of mine have carbon fiber Ferraci slip-ons on his Ducati Monster and they look quite damaged by the UV and weathering. Is there a way to bring back the finish and luster once it is lost?
Also, is there a way to maintain it from day one, when the slip-ons are brand new? (I assume all brands of CF cans will require the same care).
I'm thinking at a special product or wax or anything that could help carbon fiber. Any thoughts? Thanks!
NOTE: I know packaging must be good to insulate CF from heat and that dyno runs can be harmful. Here, I'm only wondering about the questions above.
posted August 12, 2003 04:38 AM
Keep it out of the sunlight. I would imagine you can probably sand down the surface and reclear coat the exterior. Once the fiber has faded... you're screwed.
Hells Dark Lord
living life, and loving it.
posted August 12, 2003 05:54 AM
ouch..I need to invest in a bike cover then....or keep it in the garage...the sun here in southern GA isnt nice on anything.....
posted August 12, 2003 10:19 AM
Gotta tell you, friend of mine had all the Corsa CF on his Duc...The shit turned all dull and crappy looking in a couple years...Ducati said he was SOL...
claude
posted August 12, 2003 10:52 AM
In fact swft, you make me think that the slip-ons are not Ferraci but something like Forsa or maybe Corsa like you wrote. Maybe they are simply using low quality CF? SHould I stay away from CF exhaust because of this? I suppose Titanium is a better choice?
jonwright
posted August 12, 2003 11:22 AM
From the Muzzy web site:
Q: What are the different muffler options and which is "better"?
A: Muzzys offers mufflers in two styles and four materials. Round mufflers are available only in aluminum. Oval mufflers are available in carbon fiber, titanium and stainless steel. The standard muffler shipped with a stainless steel exhaust system is the round polished aluminum. The standard muffler shipped with the titanium exhaust is the oval shape, either in titanium, carbon fiber or stainless steel. Any muffler is available with any exhaust by ordering the correct part number for the combination. Oval carbon, oval titanium and oval stainless steel are extra cost items when ordered with a stainless header.
Any oval muffler (including bolt-ons) can be ordered either in carbon fiber or titanium at the same cost. Oval stainless mufflers are generally slightly less. In general the core diameter and length are the same regardless of shape and material. Therefore, performance and sound level is the same regardless of material or shape. Special "quiet" cores are smaller and are available at a slight performance penalty and extra cost. MUZZY Mufflers are packed with a special hi temperature sound absorbing fiber material and should always be repacked with this material. Carbon fiber mufflers are not recommended for extended high temperature operation such as found in dyno testing or extended periods at high power. Care must be taken to ensure that carbon fiber mufflers are kept well packed to avoid heat damage.
Features: The round aluminum muffler is highly polished and incorporates polished stainless steel end caps. The end caps are riveted in place and are easy to re-pack by drilling out and replacing the rivets. The standard aluminum muffler weighs about 3.5 pounds. The oval mufflers incorporate end caps machined from solid billet aluminum and highly polished. The exhaust tip is polished stainless steel. The titanium mufflers features a brushed finish. The end caps are fastened with polished button-head allen screws which are easily removable to facilitate re-packing. The oval titanium muffler weighs 4.6 pounds, the oval carbon 3.5 pounds.
Q: How do I care for the finish on my Muzzy Exhaust?
A: The stainless steel systems have a brushed finish. Over time they will turn yellow and may become stained. The color can be lightened and most stains removed by scrubbing the tubes with a Scotchbrite® pad and WD-40®. The titanium systems will change various colors due to variations in temperature and they can also be cleaned with the Scotchbrite pad. Aluminum mufflers can be polished with any popular aluminum polish such as Simichrome, Blue Magic or Mothers. Carbon mufflers can be cleaned with a plastic polish like Plexus or Meguires. The end caps on the oval mufflers can be polished with aluminum polish.
posted August 12, 2003 11:23 AM
Or you can contact Nick at CycleTricks and he can redo your CF can in different colors. Not my thing...but he does pretty good work.
k bryant
Sponsor
posted August 12, 2003 12:39 PM
FYI - Ferraci carbon mufflers are all made by SuperTrapp/Kerker. ST/KR is not known for using hi-temp resins/material. They do not manufacture the carbon shells, they buy them from the same vendor that most of us do. But there are several different grades of "economy". Higher temp, more $$$$$$. Most are using 375 - 450 degree materials. If you don't keep them packed really tight, especially on a Duc, they will degrade fairly quickly. I don't think the UV rays have as much to do with it as heat cycling. I've had good luck with using a coat of good quality car wax. Surprisingly, it does not burn off like you'd think it would.
claude
posted August 12, 2003 05:06 PM
Good infos guys. Thanks a lot for your input!
0.23573088645935 seconds processing time
