BIKELAND > FORUMS > ZX12R ZONE.com > Thread: OK let me start over (what is the best pipe for me) NEW TOPIC NEW POLL POST REPLY
MarkZX12RKX500
posted July 29, 2003 09:04 PM
OK no turbo!, I have 5k what pipe is the best!whats the best air filter system.
Where should I stick the money?
Thanks for your input.
necro
My Grandma Is A Virgin
posted July 29, 2003 09:05 PM
Micron.
kawachan
posted July 29, 2003 10:21 PM
BMC's or K & N (2nd generation)
Best pipe(s)
Muzzy
Akrapovic
Arata
Yoshimura
Hindle
Micron ........and a few more
In no particular order, although I did start at #1 :-)
RED NINJAS RULE!!
RAC4IT
Bergie
posted July 30, 2003 01:42 AM
I have 5k what pipe is the best!Where should I stick the money?
You have 5k what? 5k Dollars $$$? If so please send the $5000 directly to me. In exchange I will send the best pipe and filter for you.
tuusinii
posted July 30, 2003 01:58 AM
With that much money I'd invest it at least in Ohlins...
Hells Dark Lord
living life, and loving it.
posted July 30, 2003 05:12 AM
a pipe...Bbox, K&N or BMC filter, PC, block off the Kleen system, timing advance, drop tooth, Graphicartsmotodesign.com undertail, throttle meister, and a few other goodies as wanted....lol Race tech front fork springs, and an Ohlins shock....or Penske..whichever you prefer...
posted July 30, 2003 06:49 AM
Do not block off the Kleen Air system, Use it as a vacume to the crank case and gain a little. With a PC3r, no timing advancer needed. Get the BMC Race Filter, you will curse a lot less when trying to install it. You cannot beat the Ohlins rear shock for ride and adjustability
k bryant
Sponsor
posted July 30, 2003 08:42 AM
"You have 5k what? 5k Dollars $$$? If so please send the $5000 directly to me. In exchange I will send the best pipe and filter for you. "
I second that...
jonwright
posted July 30, 2003 08:59 AM
Tell ya what. Just send me 1/2 and I'll take care of you.
As you can see, I'm MUCH cheaper than the other guys.....
Hells Dark Lord
posted July 30, 2003 11:31 AM
I use a PCII Vince...need the advance... And the K&N's were easy to put...hahahahha
0.40462303161621 seconds processing time
