BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Anyone know how to wire a relay? NEW TOPIC NEW POLL POST REPLY
ninja12
posted July 22, 2003 08:24 AM
I'm going to try this myself.
http://www.bikeland.org/board/viewthread.php?FID=13&TID=8087&set_time=1058591444
I don't know squat about electronics.
I am tring to activate the resistor when i trigger the
nitrous.
I need to know how to wire this.
The relay has 5 prongs. 30, 85,86,87, and 87a.
It appears that I have 6 wire to manage for this project.
12v, ground, temp wire in, temp wire out w/resistor,
temp wire out w/o resistor, trigger from nitrous.
Maybe i can use the 12 trigger and not need a power source.
HELP!
TedG
posted July 22, 2003 02:50 PM
For the resistor part:
Temp wire in to 30
temp wire out wo/resistor 87A
temp wire w/resistor 87
nitrous trigger to 85
It all depends on the trigger from the nutrous. If the trigger is 12 volts when activated you hook 86 to ground. If the trigger is Ground when activated you hook 12v to 86.
ninja12
posted July 22, 2003 07:35 PM
thanks ted.
Cowboy
posted July 29, 2003 10:25 AM
ok,my nitrous button has 12v to it all the time and then when i hit the button it grounds.Does that mean 12v to 86?And do i leave the buton wired the same and just splice into the wires or do i actually use the relay to activate the resisor and the nitrous solenoid now?yep,i'm a idiot.lol
ninja12
posted July 30, 2003 07:51 AM        Edited By: ninja12 on 30 Jul 2003 09:20
My understanding is (85) and (86) are your + and -,
when both or present relay is active. Use either to complete the circuit.
I would wire them just like your nitrous, and activate both with the same wires at the same time. (30) is temp wire from radi.
Cowboy
posted July 30, 2003 11:06 AM
Your exactly right ninja12.I just had someone explain it to me on paper and its simple.Just splice the 85 and 86 in on each side of your solenoid and when your solenoid is activated by the button the relay switches over to the wire with the resistor.
ninja12
posted July 31, 2003 12:34 PM
This board stuff is great. One day i'm begging for info
the next i'm sharing with others.
Thanks Ted, and others who replied on the other boards.
ninja12
necro
My Grandma Is A Virgin
posted July 31, 2003 09:32 PM
ninja12,
Are you satisfied? Um, well let me ask that differently. Has your question been answered?
ninja12
posted August 01, 2003 10:15 PM
Temp wire in to 30
IT DON"T GET ANY BETTER THAN THIS!
Any better he would have to come to my place and do the work.
WOW!
Yeap my question was answered to the fullest .
0.24086594581604 seconds processing time
