BIKELAND > FORUMS > ZX12R ZONE.com > Thread: False Neutral?? NEW TOPIC NEW POLL POST REPLY
MarkZX12RKX500
posted July 07, 2003 11:28 PM
False Neutral??
I've noticed a false neutral 3rd to 4th gear and it makes a rattle once in a while,
Is this normal maybe I am not shifting hard enough? Will this go away?
MEANGREEN
GOZR
GOZR
posted July 08, 2003 06:26 AM
yep!
no
-G
KAWAZILLA12R
posted July 08, 2003 09:39 AM
My bike does the exact same thing. been doing it since new.
it's a 03 with 2700 miles.
Has not done it since I was told by the Kaw dealer to up shift without the clutch. They were right, shifts so smooth without using the clutch. Can't hardly feel it going to next gear. Took a little getting use to get the shift timing right when letting off the throttle. I Love it now
I know, I know, I hear it from everyone. Shifting without the clutch is going to ruin your transmission. Well, if you feel what it does when finding the False Neutral, then when I say "that will ruin your transmission.
Try shifting without the clutch.......I bet you'll like it
Protected By:
Les Baer "Thunder Ranch"
Bushmaster "Shorty w/AK
SA- Super National Match
Rem. 700 PSS .300 Ultra
ScaredyCat
posted July 09, 2003 03:31 AM
Yep, the only time I get false neutrals is when using the clutch. Shifts up much nicer without it.
As for ruining your transmission, I've had GPZ900, ZXR, ZZR and have always shifted up like this, never had any gearbox or clutch hassles. And you can feel that it is causing less wear and damage because it just slips in smoothly. When rolling the throttle off gently with pressure on the lever you hardly notice it changing gear.
The'box is constant mesh - who's telling you it will screw-up your box? It would on a car obviously but that's a whole different concept.
If it ain't broke, BREAK IT.
  Ignore this member    Click here to send ScaredyCat an ICQ message. Click here to add 313822511 to your ICQ list.
posted July 09, 2003 05:29 AM
If you are having probs still, try adjusting the shift lever.
GOZR
GOZR
posted July 09, 2003 06:22 AM        Edited By: GOZR on 9 Jul 2003 07:22
Yea Clutch! ..Ffffffff! too much weight take it off...
-G
posted July 09, 2003 06:39 AM
You guys will find that the shifting gets much better with good syn. oil like the Motul 300V or equiv.
Doug
posted July 09, 2003 06:41 AM
I used to be a big fan of RedLine, but it's too hard to get where I am. Mobil MX4T is available and cheaper.
KAWAZILLA12R
posted July 09, 2003 09:29 AM        Edited By: KAWAZILLA12R on 9 Jul 2003 10:32
swft,
Did it, lowered it about an inch, no diff
still false netrual between 3rd and 4th, about 3 times a day (in town shifting)
Shifting without the clutch is the fix.....for my bike anyways
I got the 4 year warranty, and if anything goes wrong, I'll take it back to
the dealer and let the tech who told me not to use the clutch work on it.
He and I had a very long discussion on this subject, it took alot of
convincing to get me to shift my bike without using the clutch, but I am
sold on it now.......
I also use the Mobil MX4T.......made no diff either $6.88 qt (Walmart)
Protected By:
ScaredyCat
posted July 10, 2003 07:43 AM
Doug,
thanks for the answer to a question I posted earlier. I don't have much info on the effects of oil on clutch performance, apart from the obvious additive avoidance. Does Motul have superior shear resistance - if so it should only give the same gearbox performance for longer....?
The only thing I can see that would make changing smoother is having a more viscous oil, reducing shock-load metal-to-metal.
I'm not an expert on gearbox oil performance, and I'd like to hear opinions!
Cheers
0.30409598350525 seconds processing time
