BIKELAND > FORUMS > ZX12R ZONE.com > Thread: fender bolts NEW TOPIC NEW POLL POST REPLY
aliveagain
posted June 16, 2003 05:44 PM
fender bolts
what size do I use if I want to remove the reflectors on the fork/fender?
ZHooligan
Post Whore Extraordinaire!
posted June 16, 2003 07:23 PM
On the 2000 you can just re-use the the same bolt.
future; -- Youth is forever.
posted June 17, 2003 02:33 AM
I think its M6- 40mm I dont know its been awhile since Ive screwed around with them. Any hardware store would have them.
zxlnt
posted June 17, 2003 02:43 AM
I "think" you'll have to cut the bolt if you plan on just replacing it. The stock reflector has a stand off and the bolt is pretty long. It might hit the brake rotor. In any case I used some lockhart bolts on mine and ended up having to cut them shorter to clear the brake rotor.
0.41012096405029 seconds processing time
