BIKELAND > FORUMS > ZX12R ZONE.com > Thread: zx12r stator problems NEW TOPIC NEW POLL POST REPLY
Big country
posted August 02, 2014 08:11 PM
Ok i see alot on here about stators and rectifiers but my question is a little different... I have a 2001 zx12r with a ricks stator and rect, i replaced them the first time because the rect was getting super hot and melting wires, and wasnt charging, after the new install i had melted wires again, so i cut the wires and ran new 10gauge thhn oil resistant wires from stator to rect straight through, to keep the heat down, now its not charging again... Please help on what i can do to fix it without spending another $200... Or a better was to test because a-b 5vac b-c 5vac c-a 5vac all wires ring out ok
2001 zx12r custom paint,
stretched, 16,50,
runs 5.80's 1/8th mile @117mph
Big country
posted August 03, 2014 06:25 PM
Anyone out there with some knowledge or how to fix this thing before sat so i can race it? Charging in between rounds and running without my headlights plugged in to save battery is kinda hard to do
stretched, 16,50,
frEEk
posted August 04, 2014 10:45 AM        Edited By: frEEk on 4 Aug 2014 18:46
I had the stator trouble too, as many of us did, but sounds like you already went thru all the usual culprits and fixes. Sounds like you need a proper electrical expert to diagnose that one.
Only thing that comes to mind is to double check you wired it up correctly.
Big country
posted August 04, 2014 08:00 PM
I love this bike so much, it has been nothing but trouble, i have close to 16k in this bike...90% of shops around here wont except liability for a custom bike and i have to drive 2 1/2 hours to a shop that will but obviously he isnt cheap, he is the one that installed and troubleshoot the wiring harness... The wierd thing is i rode it today about a 3 mile ride and it was charging and i havent done anything but pulled stator cover off and looked at it and bolted it back together... Cant figure out why it comes and foes
stretched, 16,50,
Harpoon
Hired Gun
posted August 05, 2014 05:19 AM
Stator problem
Sounds like you may have an oil flow problem. If your stator is not getting enough oil flow around it, It will over heat. Take your cover back off and check the oil ports. They could be clogged.
Do you feel lucky?
Big country
posted August 06, 2014 06:09 PM
I checked the oil ports tonite... Sure enough it was clogged, i was tired and did a no no... I used permatex on it like an idiot.. Thanks for all of your help guys..
stretched, 16,50,
0.35348391532898 seconds processing time
