BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Cam degreeing NEW TOPIC NEW POLL POST REPLY
jessz1
Half the wheels, twice the fun
posted November 30, 2001 12:17 PM
Cam degreeing
Got lots to do to the 12 this winter. Muzzy clutch, basket, braided brake lines... Anyways, I am going to check my valves and was wondering if degreeing the cams was worth it. My bike peaks a little lower and made a little less horse than most others and I think the cams might be the problem. Anybody know of a good place to buy the cam degreeing equipment? Tired of borrowing my buddies. Also are the cam sprockets pressed on? Curious to see what I'm getting myself into. Any help is appreciated. Thanks!!
I'm never satisfied.
  Ignore this member    Click here to send jessz1 an AIM message.
RobMuzzy
posted November 30, 2001 12:27 PM
The cam gears are pressed on, however Muzzys as well as other suppliers offer adjustable sprocket kits. You should use the largest degree wheel you can find(at least 12 inch.)Doug Meyer has written a very good step by step how to degree cams article that I am sure he will send you if you ask him.
jessz1
posted November 30, 2001 01:11 PM
Thanks Rob!
Doug where ya at? I would be very interested to look at your degreeing article. I have done all my old Kz's This will be my first modern bike though, a refresher would be nice. Thanks!
redelk
Please... speak to the hand.
posted November 30, 2001 01:48 PM
I too, would be interested in seeing the article
Seeing how I'm not really as excited about riding in sub-zero temps as I used to be... It's a project I'm might consider tackling this winter.
silver01bullit
on here too much
posted November 30, 2001 02:15 PM
Me three, like Jessz, I figured while I was in there I might as well do it. Not sure of the optimal settings for the Akrapovic exhaust so I think I'll start at +1 intake -1 exhaust and take it to the dyno and play
  Ignore this member    Click here to send silver01bullit an AIM message.
cliffrandall
posted November 30, 2001 02:28 PM
From what I understand Doug mentioned that he'd be out of town this week test riding some of the new cruisers, for a major cycle magazine.
Cheers,
Cliff
Y2KZX12R
CompetitionCNC.com
posted November 30, 2001 02:29 PM
cam timing
silver, 103/101? thats an excellent choice for the street.
I had 102.5/101 from the factory and the bike ran great in the midrange and made 181 hp.
If you drop the block the intake at 103 will be very, very tight. The intake valve will be very close to the piston. Make shure you check the intake valve clearance!
104 might be better. Maybe 104/103?
Y2KZX12R
CompetitionCNC.com
Claude
posted November 30, 2001 02:33 PM
Degreeing article
Doug, I also would like to get this article. My e-mail is: claudevail@videotron.ca
Thanks!
VINCE12
Designated Drinker.
posted November 30, 2001 02:56 PM
ME TOO!!!
I would also like to see this,thanks!!!
vincelemmon@hotmail.com
2012 Metallic Spark Black ZX14R
lubricity
posted November 30, 2001 03:34 PM
Maybe we can get easy to post it on his site, then we can all have access to it.
rich
a poor 12 owner
  Ignore this member    Click here to visit lubricity's homepage.
RobMuzzy
posted November 30, 2001 06:15 PM
Sorry Doug!!
We recommend 105 int. 101 exh.
jessz1
posted November 30, 2001 06:46 PM
103 or 105
So what should I try? Split the difference? Pros/cons? Doubt I'd notice a difference anyway...
Y2KZX12R
CompetitionCNC.com
posted December 01, 2001 06:29 AM
Rob, have you ever cut piston valve reliefs in the block?
Also have you any notes on piston deck thickness at the valve relief for a stock piston?
Y2KZX12R
CompetitionCNC.com
jessz1
posted December 01, 2001 07:40 AM
Piston valve relief in the block? Do you mean in the piston?
krexken
posted December 02, 2001 12:33 AM
I think he means deepening the existing notches with the pistons still in the block(not disassembling the motor). I've cut some forged flattop TRWs that way a quarter inch deep! Started with no notches at all. Lots o strip passes without a failure. I've got a 12 piston on bench. I'll try and measure it tomorrow.
Y2KZX12R
CompetitionCNC.com
posted December 02, 2001 04:48 AM        Edited By: Y2KZX12R on 2 Dec 2001 04:51
Thanks Krex.
Jess, yea I meant while in the block.
I have tooling to cut automotive pistons and have done many. But not in the block.
Y2KZX12R
CompetitionCNC.com
krexken
posted December 02, 2001 12:22 PM
The pistons are meatier than I expected, around 4mm in the thinnest spot. The factory notches extend to just 1mm over the top ring land. Shouldn't be a problem if you just cut enough room for the valve itself though. My JE's are roughly the same thickness. Any tips for cam timing on a 1361 for street and strip use, Y2K? I like max power around 10-10.5k. Doing a little headwork right now so I'm hoping to take more advantage of the kit. Probably won't see a flowbench, though. Only real restrictions or flaws seem to be the id of the seat inserts and matching of the boots and tbs. Also doing a little chamber porting(opening up chamber to new bore size, unshrouding valve seats).
Y2KZX12R
CompetitionCNC.com
posted December 02, 2001 06:57 PM
Thanks for the info.
I dont have any info on cam timing for the 1361. Havent messed with one.
As far as porting... your right , there isnt much to improve. un shrouding the intake valve in the chamber was worth a few % flow.
The low lift numbers is where I got most gains.
Castings and port design is so beyond the Iron head V8 castings of the 60's and even 90's car stuff its not even close.
Y2KZX12R
CompetitionCNC.com
jessz1
posted December 03, 2001 08:15 AM
Come on Doug! Where ya at. We eagerly await your all knowing wisdom.
DAYTONARED12
posted December 03, 2001 08:45 AM
Doug, I would like to receive this cam degreeing article also. please e-mail to: wfree@aipdaytona.com
Thanks.
NINJA12
posted December 04, 2001 10:33 AM
doug's article
It was posted on Suzukihayabusa.org topic=000428 but it's gone. Maybe webnaster can retrieve?
posted December 04, 2001 11:57 AM
I'll get it out to you guys. Problem is I might have to scan it into a .pdf. Is that OK? The original was printed in City Bike several years ago and I don't have it in digital. But, I'll get to it.
redelk
posted December 04, 2001 12:08 PM
PFD is fine with me.
So, how was the ride? Your boss has done a good job in making us behave in your absence.
Y2KZX12R
CompetitionCNC.com
posted December 04, 2001 03:35 PM
Yea, I thought Rob was a good sub.
Hopefully he will get treated better than a school sub does with a bunch of 8th graders. No offense.
Y2KZX12R
CompetitionCNC.com
hondo
posted December 05, 2001 01:46 PM
Thanks Doug!
0.25270700454712 seconds processing time
