BIKELAND > FORUMS > ZX12R ZONE.com > Thread: tired of the button heads NEW TOPIC NEW POLL POST REPLY
aliveagain
posted May 16, 2003 10:32 PM
muzzys ignition advancer uses button head allen screws and mine stripped out right away.Replaced with m4 regular allen head.It takes a bigger size wrench and has a better bite.I did have to use a dremel to grind down the inner ring and webbing on the cover to clear the taller bolts.I also had to grind down the new screws on a high speed grinder because they're only a 1/4 inch long and finding the right size could be tough.Now,atleast I can play with the adjustment and not worry about it being the last one.
0.27349591255188 seconds processing time
