BIKELAND > FORUMS > ZX12R ZONE.com > Thread: can use a switch & relay to cut off taillight?? NEW TOPIC NEW POLL POST REPLY
n da zone
posted May 12, 2003 07:55 PM        Edited By: n da zone on 12 May 2003 20:57
Can you use a switch & relay to cut off the taillight??
First, I would like to state that this discussion is for hypothetical purposes only, since it is certainly illegal.
I have ...a friend... that wants to put a single switch up on a dashboard, and it will then cut off the tail/brake light circuit. The dashboard is a preferable location, rather than reaching around under the tail piece feeling for a rocker switch or something down low and close to the chain/tire , especially if he is running 'at speed' ....
There are two feeds back to the taillight, one for the running light (always on), and one for the brake light.
My friend was thinking that two Bosch (automotive) SPDT relays would be required, each one controlling a taillight power feed... one for running light, one for brake light. Both relays would get their switching power from the one dash switch(relay solenoid consumes about .5 amps each).
Unless there is another kind of relay that will allow two power switches from one triggering current, but I .. er I mean 'he' didn't see anything on the 'net that looked like it would work, so the thinking was to use the two Bosch units.
Well, is this a challenge or a no-brainer for you electronics wizards out there? It's out of my area of expertise. Advice or ideas appreciated.
12RPilot
posted May 12, 2003 08:36 PM
I'd just tie the grounds all together through a switch. That will take care of all the lights with no need for a relay. Switch is made, lights work normal. Switch is open, no worky.
NESBA #209
Dino
posted May 12, 2003 08:38 PM
"a friend".....
uh oh
Zhooligan
Post Whore Extraordinaire!
posted May 12, 2003 09:03 PM
Good idea for my friend too.
n da zone
posted May 13, 2003 05:08 AM        Edited By: n da zone on 13 May 2003 06:11
See, that's why I like hanging out here! 12RPilot, you just saved me thousands of hours of wiring, soldering, cursing and downtime.
GREAT idea! The ground wire IS the common thread I was looking for! Thanks!
I guess I couldn't think of it because I am a 'positive' thinker , and you are such a 'negative' thinker!
12RPilot
posted May 13, 2003 06:19 AM
Just ask my wife what a negative thinker I am. She calls me Eeyore, like that donkey on Winnie the Pooh cartoons. LOL. I guess when life has kicked you in the balls enough...........anyway, glad to have helped.
NESBA #209
jonwright
posted May 16, 2003 01:11 PM
Yep. What I did. The shop manual came in VERY handy for this.
RAC4IT
Bergie
posted May 16, 2003 07:55 PM
Just remember if the bike has a PC3 powercommander that runs power from the tail light circuit on a ZX12R, so if you kill the tail light you also kill the bike since the powercommander will not have power.
BA
posted May 16, 2003 08:15 PM
oh, good call Berg. I like that.
aliveagain
posted May 16, 2003 09:52 PM
The powercommander has it's own ground and shouldn't be affected by anything done down stream on the lights.Your friend could hypothetically also connect an old choke cable to the license plate with a hinge should he be concerned about aerodynamics of the plate sticking out in the wind.
0.22815799713135 seconds processing time
