BIKELAND > FORUMS > ZX12R ZONE.com > Thread: question regarding clutch lever a 2002 zx-12r NEW TOPIC NEW POLL POST REPLY
CharlieTuna
posted April 27, 2003 04:33 PM        Edited By: CharlieTuna on 27 Apr 2003 17:35
Question regarding clutch lever for a 2002 ZX-12R
Does anyone know where I might be able to find a clutch lever that allows a shorter pull? I don't want to loosen the line, since that just introduces slop. I guess my fingers are a little shorter than average, I grab the clutch lever by the tips of my fingers and after a couple hours worth of riding that can get painful.
Any help would be appreciated.
zxlnt
posted April 27, 2003 05:16 PM
U might be able to heat it and bend it in some. You'll know if u bend it too far by the loud snap sound it will make..
vmaxwayne
posted April 29, 2003 08:24 AM
I have the same problem on my Vmax and switched to adjustable levers. Works great.
I think the ZX6 or 7 might have them.
CharlieTuna
posted April 30, 2003 08:22 AM        Edited By: CharlieTuna on 5 Jun 2003 17:43
vmaxwayne- Great Suggestion! Can't believe I didn't think of it since I'm always scrounging stuff off of other things.
I found a 5 position adjustable lever assembly from a 2002 Ninja ZX-6(NOT R). The part number for the assembly is 46076-1165, you will also need a 92066-1077 plug. Ron Ayers has the lever assembly for $28.40 and I forgot how much for the plug. I ordered them and will see how they work out. For this price I will try this setup rather than modifying the existing lever.
Thanks for the great idea.
vmaxwayne
posted April 30, 2003 09:51 AM
Charles:
Most welcome.
Let me know how it works out and I'll order one as well.
Wayne
posted May 01, 2003 05:19 AM
Hey, is that lever black? ZHooligan has a black brembo master, and of course, the stock clutch lever is not black!
CharlieTuna
posted May 02, 2003 04:52 PM
I'll let you know when I get it.
CharlieTuna
posted May 09, 2003 12:35 PM
I just received the lever from Ron Ayers via UPS. Once I get a chance to install it and see what problems(if any) that I encounter I will post in this thread.
The lever is all black BTW except for the adjustment knob which is chrome.
posted May 09, 2003 12:48 PM
Ok, cool!
vmaxwayne
posted May 09, 2003 03:09 PM
Yo Charlie:
Do they offer natural aluminium colour??
Don't want to buy two.
CharlieTuna
posted May 09, 2003 08:27 PM
About the only thing I can tell you regarding color is to look at some diffent model year ZX-6. The black is from a 2002 ZX-6. Other years may have had different colors. I am just glad I found one at all. At first all I found were hydraulic adjustable clutch levers.
jonwright
posted May 09, 2003 11:24 PM
Fitting a hydrolic clutch would be an interesting project, I'd think...
CharlieTuna
posted May 14, 2003 03:07 AM
I installed the ZX-6 clutch lever last night and took the bike out. The lever does fit with minimal hassle. I ran into a little problem because of the Heli Bars that I have on my bike. I had to trim a little plastic on the switch to get the lever rotated to my liking. If you don't have Heli Bars this is a direct bolt on.
At level 1 it seems like a longer pull than the stock lever. At level 5 it is a shorter pull than stock by ~1/4"-3/8" in distance. This may not seem like much but it does help me out a bunch.
Next project is seeing if the brake lever from the new ZX-6R will fit the 12. I want both levers to match in color. The ZX-6R lever is black and looks like it will fit.
vmaxwayne
posted May 14, 2003 03:50 AM
Charlie:
Got any photos?
CharlieTuna
posted May 14, 2003 07:00 AM
Give me some time on the photos. I can get some this weekend after borrowing a camera.
CharlieTuna
posted May 16, 2003 02:34 PM
Here are a couple of pictures for those who are interested:
Picture 1
Picture 2
12RPilot
posted May 17, 2003 05:00 AM
I like the black. I'm off to go scrounging. Now if somebody can just distract my buddy with the zx-6............
NESBA #209
CharlieTuna
posted June 04, 2003 06:32 PM        Edited By: CharlieTuna on 5 Jun 2003 15:40
A little update action for those interested. The following part numbers are for an adjustable, black clutch lever assembly and a black brake lever. These are direct bolt-ons if you haven't done anything with your handlebars(such as using the Heli-Bars). If you have the Heli-Bars you may have an issue getting the lever rotated to your satisfaction.
For the adjustable, black clutch lever order Kawasaki part number 46076-1165.
For the adjustable, black brake lever order Kawasaki part number 13236-0024.
These parts are direct replacements.
edit- Also you'll want to order 1 of a 92066-1077. This is a little plastic plug to put in a opening on the top of the clutch lever housing.
ZHooligan
Post Whore Extraordinaire!
posted June 04, 2003 10:18 PM
Thanks for the info. Swft is always giving me crap about my black brembo brake lever with my stock silver clutch lever. Now I can get a black clutch lever!!!
future; -- Youth is forever.
posted June 05, 2003 05:03 AM
*hehhehheh* I'm just trying to support the economy!
REDRIDER
posted June 05, 2003 01:37 PM
Mr.Tuna
Whats the plug for?
ZHooligan
posted June 05, 2003 02:30 PM
Ron Ayers doesn't recognize the part number!
CharlieTuna
posted June 05, 2003 04:54 PM
The part numbers in my post dated June 4 are correct. If you call up Ron Ayers they will get you the right stuff. Of course you can also double check via the buykawasaki site diagrams. The clutch lever assembly is from a 2002 ZX-6(NOT R), you will find it under the 'handlebars' tab. The brake lever is from a 2003 ZX-6RR, and is under the 'front master cylinder' tab.
REDRIDER- I am not sure exactly what you are referring to. If you are referring to the plug part number that I stated above, the reason for that is that the ZX-6 clutch lever assembly has a little hole in the top of the housing. The plug is to fill that hole so that everything looks 'stock' except that your lever is now black and has 5 positions of adjustment.
I am not trying to 'plug' any particular store or anything like that if that is what you are referring to. I originally just wanted an adjustable clutch lever and figured while I was at it I would want it in black rather than the chrome or silver or whatever you want to call that color. Thus this became a little quest for a pair of black levers that looked like they came that way on the bike to begin with.
ZHooligan
posted June 05, 2003 05:09 PM
i'll try it again!
CharlieTuna
posted June 05, 2003 05:38 PM
If its any consolation, I had to call Ron Ayers to get the parts for the very reason that you stated, ZHooligan. I was hoping that once I had ordered the parts from them that the numbers would be in their database, but I guess it doesn't quite work that way.
0.29401302337646 seconds processing time
