BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Muzzy Camshaft NEW TOPIC NEW POLL POST REPLY
Kaw Man
posted April 11, 2003 03:52 PM
Muzzy Camshaft
Doug how much hp is the cams put out. Do you need the 1270
kit to run these cam. Cams 0003-00010 and Spring set 0025-00005 Can I Run These Camshaft in a Stock Motor.
  Ignore this member    Click here to send Kaw Man an AIM message.
posted April 11, 2003 05:32 PM        Edited By: dougmeyer on 11 Apr 2003 18:33
Cams don't "put out" horsepower. They only allow you to build the combination you want. It is the total combination of the engine that creates the power. Without testnig a given combination with and without a given cam profile, it is impossible to honestly answer that question.
But you knew that.
I edited my post on LAB to add a sentence I left out. I should have added. "These cams are for race engines only, 1270 minimum.
You would certainly suffer a power loss with these cams in a stock engine."
Doug
0.26586198806763 seconds processing time
