BIKELAND > FORUMS > ZX12R ZONE.com > Thread: swing arm question NEW TOPIC NEW POLL POST REPLY
KINGKWIK
9.36@ 149.23
posted September 18, 2012 11:31 AM
swing arm question
just wondering if an arm off an 01 zx12 would bolt on a 99 zx11... i know its a long shot but a buddy wants to stretch his 11 and the screwed up arm on the 11 doesnt work with extensions
If it has wheels or tits its bound to be trouble!!
chuck762
posted September 21, 2012 03:02 AM
Check ron ayers part list between the two to see if they share any common parts. Kawasaki uses the same part numbers on all their bikes so it makes it fairly easy to check parts. The linkage from the ZX12 is also the same as several other models so anything is possible. The list also gives bearing (you can cross reference the number to the bearing dimensions) numbers and spacer dimensions so you can do some math and see if the swap is possible.
I installed a 03 ZX9 arm on my ZX12 to shorten the wheel base and it was a fairy easy swap.
moko
posted November 06, 2012 06:41 PM        Edited By: moko on 7 Nov 2012 02:44
they mod zx11 arms
thompson custom cycles
http://www.tcconlinestore.com/ProductDetails.asp?ProductCode=STS%2D3003
and this guy put a gsxr1000....'02 on his
http://www.zxforums.com/forums/zx-11-forum/63984-modified-11s.html
hes from poway cycles in california......he has a kit to make zx7 wheels fit.....zx7rear is 10 lbs lighter then the 11
0.35406994819641 seconds processing time
