BIKELAND > FORUMS > ZX12R ZONE.com > Thread: running lean. NEW TOPIC NEW POLL POST REPLY
racerx
posted March 11, 2003 12:47 AM
running lean.
My 00 is pretty much stock.besides getting the different altitude ecu,is there any way of making this bike run a little richer?can any sensors be adjusted?or????
posted March 11, 2003 04:09 AM
You could put a resistor on the coolant temp sensor, but its not very reliable. Its very sensitive to weather.
You can also oil down the stock air filters with tacky oil (dirt bike kind).
Block off the KLEEN system. Gut the cat and poke some holes in the muffler. You can also get a "heat blanket" from Y2KZX12R to install between the frame and engine.
You can also slot the ignition pickup sensor to advance the timing ~2degrees
0.28771591186523 seconds processing time
